pushrod adjustment
Old Sep 23, 2025 | 11:37 AM
t150vej's Avatar
t150vej
Originally Posted by randallissimo
Ugh. No, I am not going to forget everything I have seen on youtube, that is just plain ridiculous, period. There are some excellent channels from very experienced and competent builders if you look. And I wasn't asking how to adjust lifters, or what cams need which rods. I am asking about the oil in hydraulic lifters.
Forget what I have, it's not important. I would like to know is: if a bike has been sitting a while with a lifter on a cam lobe holding open a valve all day, I would expect it to be bled down from the pushrod pressure, just as it does a while after you've adjusted it. Isn't this why some bikes tap some when started cold until the lifters pump up? So if it is already bled down, what happens when you put that lifter on a cam heel and take up the slack before putting the proper number of flats on it? This is where I become confused.
If this has already been explained, please tell me again. Can be hard to pull the useful and to the point info from the noise sometimes.
Some will leak down, sometimes not. A quality will never rattle on start-up though they can appear to leak off quickly when adjusting..
There is a spring inside the tappet that will hold enough pressure to adjust it correctly even if it leaked down. Others may open a valve while extending the push rod. That situation requires you wait until that valve bleeds off before proceeding.
If this doesn't explain it to your understanding, I suggest you get into the job and post again if you run into issues or have questions..
Old Sep 23, 2025 | 06:21 PM
Spanners39's Avatar
Spanners39
Adjustment is the same, bled or not, you just need to be more careful when setting Zero Lash if it is not pumped up....you are definitely over-thinking this. You don't check the adjustment on a hydro lifter if it is working OK, you can only check the adjustment on a hydro if you collapse the pushrod first and start again.
Old Sep 23, 2025 | 06:55 PM
t150vej's Avatar
t150vej
That's the difference between Shovelhead hydraulic units and tappets on an Evo.. Shovel starts at the bottom and an Evo tappet adjusts starting at the top.
Old Sep 23, 2025 | 07:15 PM
Spanners39's Avatar
Spanners39
?????? What do you mean? You can adjust from the bottom up on shovel but I have never done it nor heard of anybody who does.
Old Sep 23, 2025 | 07:55 PM
johnjzjz's Avatar
johnjzjz
Yea i seen it done like that 50 years ago but everything was almost new and from Harley today who knows what’s in any engine
forget the bottom up adjustment i think it was 1 turn maybe i forget but many did it that way in the 60s and 70s
Old Sep 23, 2025 | 09:51 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
This forum could use a section just for adjusting pushrods...
wjcbsr
Milwaukee Eight (M8)
15
Feb 7, 2022 05:25 AM
jfcroni44
Shovelhead
Nov 12, 2019 04:00 AM
pdeyo
Jul 16, 2013 09:04 PM
scottdoege
Nov 17, 2011 11:26 AM
Taterdog
Exhaust System Topics
23
Apr 13, 2008 06:47 PM
