question about breather
Old Feb 22, 2009 | 09:20 PM
raven28690's Avatar
raven28690
Default question about breather
can anyone tell me if this is a aftermarket breather kit and if so who makes it?
wasnt sure if you could clean it like a k&n one or not and tried to get it off. thought it may screw off but it ended up just pulling off. noticed what looks like a form of silicone gasket or possibly a glue on the back of the filter were it popped off so i guess its not mean to be took off and cleaned.
any ideas?
attached a photo of the breather on the bike
Old Feb 22, 2009 | 09:46 PM
sqdealgeorge's Avatar
sqdealgeorge
That's a bad one on the bike one day gone the next Looks good while it's there Get a K&N filter 3/8 hose male fitting doesn't look as good but it will stay in place You can use the existing bracket If you need a part # let us know
Old Feb 22, 2009 | 09:54 PM
raven28690's Avatar
raven28690
i thought the same thing about it coming off so i put some blue silicone on the back of the filter and put it back on.
when i popped the filter off, the part of the braket were the filter was is solid except for a small hole were the hose is connected on the other side.
so i would probably have to use another bracket.
thats what i couldnt figure out. seems the filter and bracket both would have to be replaced unless the manufacturer intended for the filter to be put back on with silicone.
never have saw a breather setup like this one so it stumped me. should have snapped some pics when i had the filter off. may have to do that anyhow so it better shows what im referring too.
Old Feb 23, 2009 | 06:57 AM
sqdealgeorge
Take that bracket off use a small die grinder or hack saw cut off that existing hose fitting so when your done we have just a hole big enough to take that new K&N breather filter with the 3/8 in hose fitting Push the fitting through the hole attach the 3/8 in hose at the back (with hose clamp ) and bingo you're on the road again ! J&P Cycles shows a K&N p/n 402-041 or Uni filter CCI P/N 11967
Old Feb 23, 2009 | 12:16 PM
raven28690's Avatar
raven28690
now that sounds like a plan.
thanks for the tip george.
Old Feb 24, 2009 | 02:18 AM
94Springer's Avatar
94Springer
4th Gear
Default Saddlebags
Noticed your saddlebags, am putting on a set from Saddleman, how are yours attached, are they removable, look nice on a springer....
Old Feb 24, 2009 | 03:11 AM
raven28690's Avatar
raven28690
thx
mine is mounted exactally like on the heritage softails.
they r removable but not a quick take off type. love having saddlebags as i usually have both sides filled so i have never thought of removing them anyhow.
Old Jun 8, 2009 | 09:24 PM
Speed O's Avatar
Speed O
5th Gear
Default crankcase breather filter
Kuryakyn part #8515 cost around $31.00 I looked it up,I use to have one on my Shovel.
Speed O.
Old Jun 8, 2009 | 09:41 PM
raven28690's Avatar
raven28690
thx man.
found the breather in my j&p catalog a lil while back but still using the one thats on it until i get ready to put some braided line over the breather hose then i will just change both at the same time.
wideglideCVO
14
Aug 4, 2024 07:26 AM
tunafisher729
Jan 11, 2019 01:37 PM
dontdropit
Jun 14, 2016 09:42 PM
galaxyfe
Dec 23, 2014 09:29 PM
MKZFATBOB
General Topics/Tech Tips
Aug 26, 2013 01:34 PM
