GPS power
Old May 8, 2009 | 08:46 AM
dkfxr's Avatar
dkfxr
Default GPS power
I have an 89 FLHS that I want to add a GPS to. Any suggestions on type and where is the best place to get power from?
Old May 8, 2009 | 08:56 AM
AK97fxdwg's Avatar
AK97fxdwg
I've been doing a little reading plus just used a non-bike version, but the Garmin Zumo 550 looks like a good unit. I'm curious as to what feedback you get about the power source also since the batteries only last about 3-5 hours.
Old May 8, 2009 | 01:54 PM
t150vej's Avatar
t150vej
Well take the dash off... there's a witch's nightmare of wires and breakers under there - pick one you like.
Old May 8, 2009 | 05:46 PM
riden2low's Avatar
riden2low
I have the unit and I ran a wire to the wiring harness down by the battery on my 93 fatboy. I also got a bracket that mount the garmen XM radio antenna. I like it. Wash the bike with it on and never worry about getting it wet. Been thru a few rain showers with it and never bothered it. I can take it off and use it in my truck, GPS not the antenna. I wish it had a bigger screen but I like for what it does. Works great when you want to record the trip that you had been. Save it and then you can run the same route again.
Old May 8, 2009 | 06:32 PM
the_ogre25's Avatar
the_ogre25
There should be a large gauge red wire that comes off of the main circuit breaker under there, it is used to run the radio/cb on the ultra's.
Old May 8, 2009 | 07:45 PM
ngoti8tor's Avatar
ngoti8tor
Check out this thread.
https://www.hdforums.com/forum/softa...ed-my-gps.html
Old May 8, 2009 | 07:46 PM
pajoe's Avatar
pajoe
We have a cigar lighter that I use for power. I originally used an older Magellan RoadMate (1040?) but a year or two ago got a good price on a TomTom Go920. I like the TomTom much better but the Magellan had a brighter screen that was easier to see in the birght sun. TomTom now has subscription plans for maps for the Go920, it is about $11-$12 for a new map, made available about every 4 months . Magellan costs much more for a new map made available every year or so. Neither of the GPS units were designed to use on a motorcycle but http://www.ram-mount.com/ makes mounts for almost anything. You can spend a lot of money, or just buy a cheap one to use until you figure out what features you really need. They all will get you home if you are lost, it may not be the best way but it will get you there. Garmin and TomTom are the largest GPS makers, and Garmin has some good units for the motorcycle, but they cost more than the TomTom model for the motorcycle. I use thin plastic wrap to cover ours when it rains enough to make it wet, and the ram mount holds the plastic in place.
on edit: I think it was a Magellan 3010, not a 1040
Old May 8, 2009 | 09:41 PM
dkfxr's Avatar
dkfxr
Thanks for the different ideas. I have an older Garmin on a different bike that I want to replace but was unsure how to mount one to a Harley.
Old May 9, 2009 | 10:36 AM
riden2low's Avatar
riden2low
Originally Posted by ngoti8tor
Hey thanks for thead. Thats a good mount. The Garmin mount that comes with the unit has a U bolt clamp. Yep, pull the Garmin off of it's mount when I am just running around but when I hit the road I put it on and it sure has helped me when I am looking for a gas station
Old May 9, 2009 | 01:48 PM
96 Ultra's Avatar
96 Ultra
You might want to check out the Garmin NUVI 500 or 550 its portable, weather proof and you can take it with you ANYWHERE....
Sactown K
Electrical/Lighting/Alarm
May 6, 2019 10:28 PM
NoChute
Mar 3, 2012 11:04 AM
oricko
Aug 31, 2010 05:01 PM
camilo4x4
Apr 11, 2007 12:39 AM
capt42a
Mar 30, 2007 07:13 AM
