Ultima 127 problem
Old Mar 28, 2011 | 05:06 AM
  #131
Classic Beast's Avatar
Classic Beast
Just as an update to the oil problem I had, the compufire charging system spacer I used was too small and allowed the seal to leak from the primary into the engine, then I installed a breather in the primary ever since then it seems to be good no problems.
Old Mar 28, 2011 | 06:40 AM
  #132
miacycles's Avatar
miacycles
CB, glad to see you have your problems sorted out!!! As with you, I too am looking forward to this years riding season.
Old Jul 20, 2013 | 03:48 PM
  #133
90hotrod's Avatar
90hotrod
I realize this is an ols thread but I started it back in June of '09 concerning a engine problem w/my Ultima 127, here it is 4 years and less than 5,000 miles and I am having the same problem. Goes into the same shop next week to see what the damages are, I will let anyone know that replies to this thread. Thanks, Choptop
Old Jul 20, 2013 | 04:50 PM
  #134
90hotrod's Avatar
90hotrod
Is Matt still the warranty guy at Ultima?
Old Jul 20, 2013 | 05:51 PM
  #135
miacycles's Avatar
miacycles
I haven't had to talk to the warranty department in a while, but I've received no notices about him leaving Ultima.
John
Old Jul 21, 2013 | 04:34 AM
  #136
Classic Beast
127 is still running strong I have over 70,000 Km on the bike so probably about 40,000 or so Km on the motor, it is getting a bit noisy though but not using any oil, might have to tear it down this winter
Old Jul 21, 2013 | 12:10 PM
  #137
90hotrod's Avatar
90hotrod
John
Thanks, Ultima supplied parts last time this happened, undoubtedly that wont happen this time, any recommendations, given your experience with the Ultima's, what Lifters, oil pump, push rods.. I might invest in, should the need arise. Thanks in advance.
Old Jul 21, 2013 | 12:49 PM
  #138
Classic Beast
I installed the S&S lifters when I first got the motor no problems since, I did buy a new oil pump but there was nothing wrong with original so its still in the box. I tried an S&S 640 cam but put the original back in as it ran stronger, the lifter rattle was about the same.
Old Jul 21, 2013 | 04:56 PM
  #139
miacycles's Avatar
miacycles
Ultima high volume, high pressure pump, Johnson or Jims big axle lifters. and any good chrome moly pushrods. If you have any questions when you get into it PM or call me.
John
Old Jul 21, 2013 | 06:51 PM
  #140
113fatboy's Avatar
113fatboy
Matt is gone the new guy is Charlie I use this number 636-931-3394 to get a hold of him
Seems to me the old number doesn't work
Rob
