Installing starter
Old Aug 14, 2009 | 08:13 PM
frantheman39's Avatar
frantheman39
Exclamation Installing starter
Hi out there - I'm installing a new starter, or trying to in my 1989 FLHTC and CANNOT get it to work properly. Is there some trick to getting it back together on the primary side so it engages? The bolt that goes to the starter keeps popping out.... and just doesn't catch. Gotta' be something simple.
Old Aug 15, 2009 | 05:39 AM
miacycles's Avatar
miacycles
There are two different starters an early and a late, they have the end of the starter drilled for two different sized bolts. If the starter you have is an after market did it come with the bolts as many include both bolt. They drill the end of the starter for both bolts with the smaller one being slightly longer than the stock one. Try threading the bolt in with out the gears installed and see if it catches. If it does let us know. If not then you have the wrong starter. Hope this helps.
Old Aug 15, 2009 | 07:42 AM
sqdealgeorge's Avatar
sqdealgeorge
1993 and down the starter bolt size was 1/4-20 1994 and up the bolt changed to a # 10-24 The inner primary's changed also as well as the starter pinion shaft/starter ring gear jack shaft coupling etc etc More than you really wanted to know
Old Aug 15, 2009 | 08:42 PM
frantheman39
Default Starter
The bolt fits the new starter. Threads right on. It doesn't seem to engage every time. Just clicks. No idea why. Only something this simple could cause such a headache!
Old Aug 16, 2009 | 07:09 AM
miacycles's Avatar
miacycles
First check and make sure that the starter is in tight and bolted flush all the way around, if it not it won't engage. Next make sure that the connections and grounds are clean and tight, you might want to put star washer under them. Lastly did the starter you replaced do the same thing, if so your problem may be the starter relay, stop/run, or ignition switch. Hope this helps
Caddo
Engine Mechanical Topics
Dec 7, 2012 07:08 PM
mostSilly
EVO
11
Aug 1, 2010 12:46 AM
terrapin88
EVO
Jul 2, 2010 02:19 PM
comsurfer2
Jun 11, 2010 02:51 PM
springer96
Jun 1, 2009 05:26 PM
