tranny dipstick access
Old Dec 28, 2009 | 08:43 AM
mjaw's Avatar
mjaw
93FXR,Did you use the stock front tin,or did you have to change it to fit the wideglide forks?
Old Dec 28, 2009 | 11:00 AM
Harley_Dude's Avatar
Harley_Dude
Originally Posted by dlnp22
Screw the standard allen top dipstick. Get one of those twist off caps(remove by hand). Not only will it solve your problem, it's very convenient rather than whipping out the allen everytime you want to check
Yep several manufacturers out there.
Old Dec 28, 2009 | 11:01 AM
98 FLHX's Avatar
98 FLHX
Changed it to a wideglide....bought one used, and had it painted.
Could have used the narrowglide fender with spacers, but got a great deal on a used one, so just had it sprayed to match.
Old Dec 29, 2009 | 08:24 AM
mjaw's Avatar
mjaw
Can I use a front fender from a FXST?
Old Dec 29, 2009 | 10:29 AM
98 FLHX's Avatar
98 FLHX
I believe that is a 41mm, wide front end....correct?
If so, it should bolt right up....
The fender I bought was from a FXDWG, and it was a perfect match.
Old Dec 29, 2009 | 05:49 PM
mjaw's Avatar
mjaw
I found a FXST fender on EBAY for a pretty good price. It also is already painted to match the bike,(vivid black). I plan on 41mm forks so it should fit ok? Also,I bought a speedy-check dipstick for the tranny.That solved the clearance problem.
jeemann99
Aug 12, 2015 02:14 PM
bgbdbrwn
Dec 18, 2007 10:48 PM
Ratbasturd
Jul 28, 2007 09:00 AM
Rich Train Driver
16
Mar 24, 2007 04:15 PM
hdchopperman
Mar 27, 2006 09:53 PM
