EV27 cam
Old Jan 18, 2010 | 02:13 PM
legacycycles's Avatar
legacycycles
Oops
Now at those speeds (80)My mileage falls back in the 30's.Anything below 3k rpms i do good mpg's,Get mine above that and its like driving an ole chevy.
Old Jan 18, 2010 | 06:20 PM
gsxrboy96's Avatar
gsxrboy96
Originally Posted by Brettfullthrottle
I have stock gearing. I have had this dyno tuned.....not sure what is going on. She burns oil however....about a quart every 1200 miles. Could this be part of the problem?
On the freeway I tend to keep her at 75 to 80. guess that's not really "taking it easy".Maybe the problem is my wrist!
a quart every 1200 miles isnt normal, and im sure thats effecting the effiency of your combustion process, but hey, if it aint breaking down or using plugs, keep adding oil ....
Old Jan 18, 2010 | 07:30 PM
miacycles's Avatar
miacycles
Here's something you can check pretty easy. Warm the bike up, put a fan on the exhaust to cool it down. Take the pipes off and look at the valve stems. If there is oil on them then the exhaust seals are leaking, no big problem. If not the next step is a little more complicated. Take the carb off and use a dental mirror to look at the intakes to see if they are leaking. If so you might want to fix them as any oil from either the intakes or rings will dilute the fuel mixture and cause problems like detonation, carbon build-up, etc. Hope this helps.
Old Jan 18, 2010 | 07:47 PM
gsxrboy96's Avatar
gsxrboy96
you mean it will look like this? lol
Old Jan 18, 2010 | 10:33 PM
B-1B_Guy's Avatar
B-1B_Guy
I ran an EV27 in my '97 Heritage. I also had SE heads, S&S Super E carb, Wiseco ProLite pistons .010 over, Supertrapp 2 into 1 w/ 18 disks, SE ignition, SE coil, SE plugs, magnecor wires. Little 80 ran like a raped ape. I had to drop in a 6 speed tranny for the long rides otherwise I'd have to stop for gas way too often. It would get upper 40's MPG is I could lay off the throttle.....
EV27 is a pretty good cam for low to mid range power, glad I went with the 27 vs the 46 for my riding style.
Old Jan 19, 2010 | 03:54 AM
pajoe's Avatar
pajoe
I am far from an expert but with our 80" and the way we ride I got about 40 mpg and some times less and with the 113" the best I can do was about 38 mpg, but usually less. I think it has to do with the amount of weight the bike is hauling and the type of roads, pulling a lot weight up and down hills that requires a lot shifting may burn more fuel than cruising down a flat open highway where wind resistance is the only major factor.
Old Jan 19, 2010 | 04:00 AM
Brettfullthrottle's Avatar
Brettfullthrottle
That DOES help! I will look into this towards the spring! Thanks!
Old Jan 19, 2010 | 06:54 AM
miacycles's Avatar
miacycles
WOW!! That as out of focus as a computer dating photo of a 50 year old !!!! LOL But yes !!
Old Jan 20, 2010 | 07:17 AM
Hackd's Avatar
Hackd
Back to the OP...
The three 'must do's' for an EVO are: Intake, Cam, Exhaust. Next would be an ignition upgrade. You don't need a single fire, IMO, just something with a higher limit. An upgraded 80" EVO should easily make the 80/80 (approx) numbers with these mods and some tuning.
There are very little miles on your bike. At 14k, that EVO is just nicely broken in, so wouldn't spend the $$$ for head work at this point. Unless you've got something going on. A good porter can work the stock heads for a 'street setup'. Anything more, and IMO, you might start looking for a replacement set of HP heads.
Your RK is the same weight as my FLHS. When I added the SE air cleaner, SuperTrapp (18 disc) slipons, and EV27 cam, it was like riding a different bike. I don't have the exact dyno numbers handy, but I know that I'm in that 80/80 range. My bike has no problems running two-up, loaded, at interstate and above speeds.
As far as MPG, I get in the high 30's around town, and the low to mid 40's out on the slab. On an interstate trip, where I'm running 70-75mph, I normally will start looking for a gas station after 160 miles, which generally leaves me with a gallon of 'reserve'.
Old Feb 16, 2010 | 11:34 PM
skipc's Avatar
skipc
Default Ev-27 done
got the work done and road tested this weekend.Very happy with results.Crusin` at 60mph and a little twist of the wick and to 85-90mph in no time.Very pleased! Thanks everyone for all of the response. Skip
Attached Thumbnails EV27  cam-hd-1-18-10-008.jpg   EV27  cam-img_2537.jpg   EV27  cam-img_2547.jpg
2duece
Engine Mechanical Topics
Dec 17, 2014 09:56 AM
WG2011
Exhaust System Topics
Apr 9, 2013 02:23 PM
12, Bob Street
24
Oct 11, 2012 05:30 PM
humblepiee30
Screamin Eagle CVO Models
Jun 27, 2008 07:50 AM
Blown 331
EVO
15
Feb 23, 2007 08:53 AM
