softail gas tank for an fxr???
Old Mar 12, 2011 | 12:28 AM
emwolb's Avatar
emwolb
Default softail gas tank for an fxr???
i looked at a softail tank today at the harley shop. the tunnel where the frame backbone resides looked square. if so, then aren't fxr's backbone also square? if the dimensions work out, will it work to use a softail tank on my 92 fxr? if someone has had experience with this, please let me know, i'm curious because i'd like the fat style twin cap tank with the center gauge console.
Old Mar 12, 2011 | 03:55 AM
fhaley's Avatar
fhaley
Just got my Flatside tanks back from the powder coater, will be installing them today. My bike is a 95 fxd, which I assume is very similiar to yours. You just have to mount the bracket to your frame at the bottom front and weld the mount for the back on the top of the frame. And yes, the backbone is square with a flat top. Hope this helps. As some on here have said, if you want to do something there is generally a way, and someone has probably already done it.
Old Mar 12, 2011 | 07:13 AM
Then Came Bronson's Avatar
Then Came Bronson
I've never heard it called a "Softail" gas tank before. I believe you're talking about a fatbob style tank with the center mounted speedo/tach console...just like this 1988 FXRS:
Old Mar 12, 2011 | 09:57 AM
1990FXR's Avatar
1990FXR
v-twin makes an aftermarket tank like that for FXRs....
http://www.vtwinmfg.com/catalogs/cyr/pdf/345.pdf
i have one on my 1990
Old Mar 12, 2011 | 11:34 AM
woodnbow's Avatar
woodnbow
I've never had the softail tank and an FXR side by side but I've been told the softy tunnel is too narrow. Road King tanks will work if you're going for the tank mounted speedo, FLH tanks will work if you just want extra fuel capacity... FXD's aren't even close, the top tube is much narrower than the FXR. That's just one of the reasons for the FXR's clear superiority as a canyon carver... ;-)
Old Mar 12, 2011 | 08:17 PM
Nate88hd's Avatar
Nate88hd
Does your 6 post key switch work? If so what wiring modifications? Looks awsome
Old Mar 12, 2011 | 08:40 PM
emwolb's Avatar
emwolb
thanks guys, that's just exactly what i was looking for. yeah, the fatbob style tank is what i was looking for, you guys gave me all the information i needed, now i can proceed with my project without as much guessing.
Old Mar 12, 2011 | 08:52 PM
1990FXR's Avatar
1990FXR
no i dont have it hooked up (see the ignition key below the back of the tank)
wouldnt be hard to re-route/extend that wiring up to there tho
i appreciate the compliment
Old Mar 12, 2011 | 10:08 PM
woodnbow's Avatar
woodnbow
"no i dont have it hooked up (see the ignition key below the back of the tank)"
That ought to keep a thief flustered for a while...
mpescatori
May 20, 2017 06:14 AM
tylerdb
Jul 12, 2013 12:56 PM
zyban
Exhaust System Topics
Jan 12, 2012 02:42 AM
mkguitar
EVO
Dec 15, 2011 03:35 AM
67zoomie
Classic
Oct 23, 2005 01:38 PM
