is this normal? or do i have an ign coil problem?
ok now on to my project, i am building a 93 Fatboy. i will post pics of the build soon. it has been completely torn down, jugs bored out, andrews cam, wisco high comp pistons, compufire adjustable ignition module, adjustable lifters, all new gaskets, motor is all back together, new stretched tank, new smooth rear fender, side mount plate bracket, fresh paint (painted it myself in my garage), drag bars, led turn signals, fat spoke rims and a few other mods.
ok now that i got that out of the way, im in the process of putting it all back together. tonight i connected the battery to check some wiring i had repaired from the previous owners hack jobs. i noticed that when i turn the ign switch on the lights would remain alittle dim for 5 - 10 seconds, then the ignition coil would click (i made sure it is the coil, you can feel it click) once it clicks all the lights are bright and everything is fine. is this normal? i checked the wiring, all looks correct. i have batt voltage at all 3 posts with ign on. (about 10 volts before click, 12 volts after click) the coil looks exactly like the crane fireball coil, but has no company markings on it. thank you for any help!!
sorry for the really long post, just figured id cover everything so you know where im at. again thanx to all of you for your help and time!!
Disconnect the coil and re check...tell us what happened please.
EDIT: also i know this is probobly gonna stir up a huge debate but what do you all suggest as a replacment for my coil. it has a compufire single fire ignition installed in it so i want something that will work with that and not give me more problems. thanx.
This is why I suspect a faulty wire is completing your circuit!
Hatch.
Hatch.
So, the short is normal and yet this one is acting differently. At 3 ohms on the coil, there would be 4 amps flowing through the circuit. This shouldn't make the headlight dim. I wonder if the coil is shorting internally under load but not showing the short with an ohm meter? Or is the coil somehow shorting to ground, such as at the mounting bolts? I think another coil to at least check with is reasonable. Even an automotive coil temporarily wired in place of the existing coil could be diagnostic (do the lights dim the same?) Also, put an ammeter in series with the coil and see how much current is flowing through that when the headlight dims.
