Ignition switch jumper wire?
Old Jul 4, 2011 | 07:03 PM
D1gger's Avatar
D1gger
Ok, I finally got it done. Here's what I found out:
the bank of circuit breakers(4 of them) are on a plate inside the gauge cluster under the top of the speedo/tach. To get in there, I had to remove the trip meter post using a small, long phillips screwdriver, then removing the two hex screws at the back of the cluster(bottom of the gauges). I lifted up the back edge and slid it rearward which unhooked the front edge, then I unscrewed the speedo cable which allowed me to flip the upper cluster up towards the back of the bike.
The jumper was a small gauge wire, dark green insulation, connecting the forward posts of the middle two circuit breakers. A quick snip and voila, the ignition position on the switch is just that, dash lights and ignition, no headlights, marker lights or tail lights. Initial testing shows that this does indeed make a difference in how the starter engages, it definately has more power and turns over much better.
While I was in there I replaced the bulb at the bottom of the speedo that was out, now I can see the trip meter at night. It must have taken me over an hour to get it all back together, though, because I had a hard time getting the speedo cable reconnected. Based on that, it will probably be a long time before I bother to take that apart again! Maybe eventually I will replace the dash lights with red bulbs for better night vision...
RANGER73
Electrical/Lighting/Alarm
Mar 24, 2017 07:07 PM
RANGER73
Apr 8, 2014 08:02 AM
jlbreaux
Jul 9, 2013 07:00 PM
Macky1986
Nov 11, 2011 09:34 PM
brian.yerich
Nov 14, 2006 11:16 AM
