1986 fxrs
Old Dec 26, 2011 | 10:12 PM
inkslinger73's Avatar
inkslinger73
Default 1986 fxrs
the previous owner changed it to chain drive(it's chain primary and chain secondary now).I'd like to change it back and need info on what and where to find the proper parts thanks.
Old Dec 26, 2011 | 11:59 PM
Spanners39's Avatar
Spanners39
Try Ebay or an indy that has done a chain conversion. Get a new belt but second hand pulleys are not too hard to come by.
Old Dec 27, 2011 | 06:30 AM
inkslinger73
thanks already been looking on ebay.thats why I posted here!
Old Dec 27, 2011 | 08:14 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
For the front pulley, use `94 and later configuration parts. Pulley, lockplate, nut, bolts, spacer, quad seal and oil seal.
The earlier pulley setups had a lot of problems with coming loose.
Unless you can find pulleys that look unused, I would buy new parts. New pulleys and belt will go 100k miles.
Old Dec 27, 2011 | 09:33 AM
Dr.Hess's Avatar
Dr.Hess
I am also a fan of new pulleys and belt at the same time. It's a big enough PITA to do the job that putting new pulleys on isn't that much more.
Old Dec 27, 2011 | 11:28 AM
grbrown's Avatar
grbrown
I'm with Dr Hess, fit all new, not secondhand. You can get the correct parts from a wide variety of sources.
Old Dec 27, 2011 | 05:11 PM
Tom84FXST's Avatar
Tom84FXST
86 is bastard stuff...still has a tapered mainshaft....most of the newer parts will not fit...which may be why it got converted to chain...the aftermarket has totally ignored the early 5 speeds. You can have your trans rebuilt with a splined shaft... so newer parts will fit, or check with supermax...they manufacture belt drive pulleys for the older stuff.
http://www.supermax.net/Pages/home.asp
Old Dec 27, 2011 | 07:22 PM
mrgto's Avatar
mrgto
Stage I
For sure get rid of the tapered shaft if you can..... I have worked on mine a few times and each time it has been a pain.
Old Dec 28, 2011 | 06:04 AM
Dan89FLSTC's Avatar
Dan89FLSTC
The mainshaft has nothing to do with the pulley hardware. All the later pulley hardware will fit.
jamesengle
Sep 9, 2017 01:52 PM
beeratthecabin
Jul 29, 2014 11:33 AM
ctluba
Wheels/Tires
Sep 20, 2012 07:18 AM
machinehed
Feb 25, 2012 11:12 AM
legacycycles
EVO
Mar 3, 2009 05:31 PM
