replace an evo with a tc
Old Dec 30, 2011 | 07:35 PM
1989 fxr's Avatar
1989 fxr
Default replace an evo with a tc
Can anyone tell me if i can fit a 88tc into my 1989 fxr? I messed up the case and would like to be on the road in the spring. found a line on a cheep 88tc but before handing out the cash I would like some info thanks.
Old Dec 30, 2011 | 08:54 PM
Spanners39's Avatar
Spanners39
All Big twins from Shovel to TC are supoosed to use the same mounting points but be aware that the FXR uses the short chaincase motor....like a Road King rather than a Dyna.
Old Dec 30, 2011 | 09:16 PM
Tom84FXST's Avatar
Tom84FXST
Not quite...the 88B motors have the same front mounts as EVOs and you can get an adapter to bolt up the rear. No other TC motor will bolt up. Look at the pic to see the type that will bolt in.
Will work
Will NOT work
If you are not afraid to cut and weld...some have successfully trans-planted an entire late model FL drivetrain...trans and all
Old Dec 31, 2011 | 12:21 AM
1989 fxr's Avatar
1989 fxr
Thanks now I know what to look for hope to be on the road in the spring
Old Dec 31, 2011 | 05:10 AM
misfitJason's Avatar
misfitJason
Not to mention that the twincams have built in offset at the primary
Old Dec 31, 2011 | 06:08 AM
Then Came Bronson's Avatar
Then Came Bronson
A twin cam in a FXR? Sacrilege!! I would fix whatever is wrong with the Evo, and press on.
But if you must…it is probably possible with the proper adapter, or with a little torch work.
Old Dec 31, 2011 | 10:57 AM
mkguitar's Avatar
mkguitar
probably cheaper to get an evo motor- my local craigslist has a couple pop up every week, most would want a rebuild or inspection.
S&S would be a good call, get a complete drop in motor build the way you want it.
or the Harley remanufactured motor, and get your numbers stamped into it.
the draw back here is that they may require your dealer pull the old motor, so that gets pricey.
mike
Old Dec 31, 2011 | 02:41 PM
Spanners39's Avatar
Spanners39
Will work
Dude, thats an A motor, the B is the one with balance shafts and will not fit....
The Twin Cam wasn't initially used in the Softail model family before the year 2000. This was due to the chassis design and vibration transfer to the Softail frame as a result of the direct (hard) mounting of the engine. Dyna models are "rubber mounted", dampening the majority of vibration transfer to the frame and rider. Harley solved the issue for the Softail family by designing an engine variant known as Twin Cam 88B. It is basically the same engine as the original (now called "Twin Cam 88A"), but with a modified engine block design that incorporates twin chain-driven counter-balancers. This caused some controversy among Harley veterans, claiming that the "Harley vibes" were a part of their motorcycles. The Twin Cam 96B engine was released at the same time as the Twin Cam 96A model, for the 2007 model year, and is currently used on all Softail models."
mike14_07
Jul 21, 2020 12:40 PM
83shovl93”strokr
Shovelhead
24
Jan 16, 2019 09:34 AM
Riun
EVO
37
Dec 2, 2018 08:07 AM
cdonis
Dyna Glide Pictures
Aug 24, 2017 05:21 PM
kevin_s
Sep 3, 2014 09:11 PM
