Help with clutch issue!
Old Jul 23, 2012 | 04:39 PM
billzflhtc's Avatar
billzflhtc
Default Help with clutch issue!
Ok, 86 flht, had the motor gone thru month ago, all is good, Im riding back 5 miles from home after a 150 mile ride (thank God) and turn corner/ down shift, go to pull in clutch, snap! cable is good, it is in tranny! the lever on trans is no resistance, old style trans. Is there a spring in there I can replace no prob? Not to mention it is the worst storm we have had since Debby a few weeks ago. I have to rev up motor let off, to shift no clutch to get it home... Any ideas?
Billy
Old Jul 23, 2012 | 05:45 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
You could have snapped the cable inside the transmission cover. Just pull off the tranny cover the problem should be obvious.
Old Jul 23, 2012 | 05:58 PM
billzflhtc's Avatar
billzflhtc
Default Shiting issue
wish it was that easy,all cables are brand new. it is an early 86 with the arm on the outside top of the end cover, that the cable connects to.. I can move that arm with my hand. Is there a spring inside that might have broken?
Old Jul 23, 2012 | 06:52 PM
bagga's Avatar
bagga
the clutch release lever inside the 6 sided cover on the right side most likely broke. it's an easy 1/2 hour fix. the part is about $10 or so. drain trans oil, take the cover off and the fingers are attached to the clutch lever on top of the trans.
Old Jul 24, 2012 | 07:51 AM
GraemeR's Avatar
GraemeR
+1 for the clutch release fingers hiding inside the right side tranny cover. I have gone through two over the years on my 86 FXR. Replace the small bearing race in there as well as they tend to shatter quite often.
Old Jul 24, 2012 | 08:12 AM
Dr.Hess's Avatar
Dr.Hess
Yup, clutch finger thingie. I'm on my 3rd in 26 years, although this one has been in there >20 years (knock on wood). I have a spare in my tour pack. I recommend only using Genuine HD, not aftermarket, and also make sure your clutch is adjusted properly at the basket (per the shop manual, using the straight edge,) as I think that if your spring is too tight, that contributes to the things breaking.
Old Jul 24, 2012 | 09:48 AM
schwinnanator's Avatar
schwinnanator
+3 on release finger, i just broke one a month ago. ordered a kit from j&p to replace the bearing, push rod, slinger and finger.
Old Jul 25, 2012 | 05:14 AM
GraemeR's Avatar
GraemeR
Do your research if it's the fingers as the early evo units did not run the oil slinger... Mine does not have one on my 86 FXR. I do have a full slinger kit in the shed that I plan to see if I can retrofit one day - but why 'f' with something hats not broken.
Old Jul 25, 2012 | 09:44 PM
billzflhtc's Avatar
billzflhtc
Ok, think I have found the issue, wish I had my phone, daughter has it lol,the pics of the parts are crazy. The fingers as you all described it on the arm, are worn alot, the two spacers and bearing that are on the endo of the pushrod? the roller bearing was non existent I mean litterally not there any more and the outside piece wore in half the inner one, I thought was part of the shaft had to beat it off and grind it back flat.. Now to wait a week for my local HD to get the finger thingy in!!!...
deez nuts
Sep 8, 2017 02:37 PM
durbFXD
Jul 14, 2013 12:13 PM
BPlo
Aug 3, 2011 05:14 PM
crzysuperj
Apr 23, 2011 01:54 PM
Shrek
Feb 6, 2008 01:02 PM
