Pulley spacer issues
Old Sep 11, 2012 | 02:44 PM
Rob85WG's Avatar
Rob85WG
Default Pulley spacer issues
Hello Gents,
I recently noticed my drive belt is squeaking and I found the belt is tracking on the outer edge of the wheel pulley. I checked the wheel for straightness and it looked ok. I looked at the parts list for my bike and found that I was missing a .2" spacer behind the stock pulley. I bought and installed the spacer but now the pulley hits the swing-arm. Swing-arm is chromed, so it may not be stock. I lost touch with the PO so I can't ask him about it. I can adjust the wheel so it doesn't hit but that makes the belt ride on the outside of both pulleys.
Question is: How much pulley to swingarm clearance should I have when the wheel is true? Has anyone else ditched the stock spacer? I'm worried it could lock up if I stress the suspension in a turn or hard breaking.
Thanks alot
Rob
Old Sep 11, 2012 | 06:05 PM
pjb's Avatar
pjb
Since almost new, I've had a chromed Softail Custom solid rim on the back of my 85 FXWG. Last year I wanted to go back to an old skool look, so I bought a spoked rim. I had sold my original rim many years ago. I found the original spacer that was behind my pulley with the original spoked wheel, and installed it. The pulley hit the swingarm, like you mentioned, so I removed it and installed the pulley with no spacer. Fit perfect. The new spoked rim was an ebay special.
Old Sep 11, 2012 | 06:49 PM
Rob85WG's Avatar
Rob85WG
OK.... Maybe the newer aftermarket wheels have a different offset to eliminate the need for a spacer. My wheel could be aftermarket also. I'll pull the spacer back off, align the wheel again and check both pulleys. I think the belt should track near the center of the front pulley. Is that right? If it doesn't, I may try a thinner spacer.
I may make it to Delmarva bike week after all.
Thanks
Old Sep 11, 2012 | 09:16 PM
hatchetman's Avatar
hatchetman
Belts can be a pain in the hoop. I eye ball my belt alignment & how it tracks on both sprockets. Just a lil tweak here & there to make it dead on.
if it squeaks, carry a bar of soap with you & rub the sides of the belt with it. Keeps it quiet until you hit rain.
Hatch.
Old Sep 12, 2012 | 04:37 AM
grbrown's Avatar
grbrown
The front pulley is much wider than the rear, so it will be happy wherever the belt runs on it! You may find just a subtle change in rear wheel alignment will solve the problem you mention.
Old Sep 12, 2012 | 07:01 PM
pjb's Avatar
pjb
as stated above, I don't think where the belt rides on the front pulley really matters. As long as its not trying to jump off.
Old Sep 13, 2012 | 08:41 AM
miacycles's Avatar
miacycles
Flat belts ride towards the tight side. So your wheel would be tracking a little to the left in the front.
John
Old Sep 13, 2012 | 05:40 PM
Rob85WG's Avatar
Rob85WG
John
Wow, that means I need to start over! Thanks for saving me from a lot of frustration. I'll head back out to the garage now.
jsbridgew
Jun 28, 2011 05:28 AM
norris
Jan 27, 2011 08:29 PM
fogcity123
EVO
24
Jul 2, 2010 04:37 PM
uzuzap
Nov 7, 2009 08:18 PM
boatsv
Jun 15, 2009 08:31 PM
