big pop after full throttle..
Old Oct 6, 2012 | 12:45 PM
mostSilly's Avatar
mostSilly
Default big pop after full throttle..
Continued from my different plug post, problem continues. After I really jump on the gas, somedtimes it will pop, then run bad and miss.. After it does, I pull over, check it over, scratch my head, wait a bit, then it runs fine. It has done this like five times now. Plugs always look fine, it just gies away.. Could I juat be overheating it real fast? My dipstick thermo never gets above about 185, getting confused, thanks for your help.. Tim.. 1988 FLHS, Mikuni carb, s&s intake, slip ons, 32amp,
Old Oct 6, 2012 | 01:46 PM
grbrown's Avatar
grbrown
One possibility is your VOES. If the vacuum hose is not connected, or split, that sort of thing can happen. What ignition do you have? It is possible whoever installed the Mikuni left the VOES off, out of ignorance or innocence.
Old Oct 6, 2012 | 03:11 PM
Spanners39's Avatar
Spanners39
You need to install a Gremlin Bell.......
Old Oct 6, 2012 | 03:38 PM
Jasper86's Avatar
Jasper86
someone needs to explain these to me. Ive seen them on bikes, and on the wall at the local shops, but never quite knew the purpose. (although "gremlin" bell makes it a little more clear)
Old Oct 6, 2012 | 06:38 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
The Gremlin Bell is supposed to scare off the road Gremlins.
The road Gremlins are the ones who make things fall off your bike.
Old Oct 6, 2012 | 06:53 PM
Mountainkowboy's Avatar
Mountainkowboy
It must be bought by someone other than you to work.
The ringing is irresistable to them, and they have to go to the bell
Once in the bell, the ringing is so loud that they have to cover there ears.
Falling out of the bell onto the ground and off your bike
So the legend goes, from WWII
Old Oct 6, 2012 | 07:43 PM
92Fatty's Avatar
92Fatty
I had a similar issue that gave me fits. It turned out to be the ignition cam position sensor plate. The glue was all melted on it. I bought a new one and it has ran like a champ since. I even went so far as changing to another carb thinking it was fuel. Changed coil etc but it ended up being the plate.
Old Oct 6, 2012 | 07:49 PM
mostSilly's Avatar
mostSilly
Gremlin Bell... Check.. Thats why it gets me home .. VOES, dont have one, I dont think mikuni carb would use it..
M3T4LM4N
Jul 31, 2017 12:53 AM
j440
EVO
18
May 24, 2015 05:25 AM
Janty
Carburetor Related
Aug 11, 2013 05:22 PM
shotgunner426
Aug 2, 2009 01:23 PM
Softbutt
Exhaust System Topics
Oct 3, 2005 01:00 PM
