Rocker Box Oil Leak Fix
Old Dec 8, 2012 | 08:20 PM
HarleyReece's Avatar
HarleyReece
Originally Posted by Bingee
I didn't see it posted here. But those rocker base screws are not all the same length. Two are 3500 and the other two are 3501's. They look the same but they are not the same length. So, did somebody put the screws in wrong?
Yup, I almost made the same mistake while putting my motor back together after bored jugs, reworked heads, and high comp piston install. I was so close to closing up theories I had to tell myself to slow down, but I wanted to hit that button so bad and hear her fire up.
So yeah, those bolts are different lengths. I think that's your issue.
Old Dec 9, 2012 | 01:13 PM
Spanners39's Avatar
Spanners39
I don't agree with that diagnosis because he got them tight....none of you are reading the post properly....he did not find the washers loose and the bolts tight....the bolts were loose and he was able to tighten them....if the bolts were too long they would have bottomed out and not tightened.
Old Dec 9, 2012 | 01:37 PM
batch's Avatar
batch
^^ Yup, that's right mate. I could still turn the bolts easily with a socket on an extension.
I started the bike up last night & ran it for a few minutes, & it's not bubbling oil out of the join anymore so all looks sweet
And man those stock pipes are quiet...
Old Dec 9, 2012 | 05:52 PM
HarleyReece
The original post stated he tryed the bolts with fingers only, and the washers were loose. Then the OP said he put a socket on her and the bolts were tight and the washers were still loose.
I think that's what we all read.
I'm not a professional harley tech, but I know what I do from wrenching on my own bike, and was only suggesting another option to check while be has the rocker cover off.
Old Dec 9, 2012 | 07:03 PM
Spanners39's Avatar
Spanners39
Originally Posted by batch
I chucked a socket on the bolt head & was able to turn it with bugger all effort at all, so that's not good.
In NZ "Bugger All Effort" means it was loose.....he couldn't turn it by hand because the notch in the rocker spindle can rest on the bolt and give it some resistance but with a socket on it turned easily.......as I said before, y'all not reading carefully....or maybe just reading it in the wrong language
Old Dec 9, 2012 | 09:11 PM
HarleyReece
Yup, wrong language. I thought it was a miss type from an auto correcting smart phone post. Batch, glad you fixed your ride man. Ride safe.
Old Dec 9, 2012 | 10:58 PM
batch's Avatar
batch
Haha, sweet as man. It's twice as bad with me mate, I don't know what I'm doing AND I can't speak proper english... I'm really farked! haha...
Lambda
Engine Mechanical Topics
11
Apr 22, 2016 07:44 AM
misterMagoo
Aug 11, 2010 10:32 AM
straydog13
Ironhead
Oct 23, 2009 06:12 PM
HDF Tech
General Topics/Tech Tips
Mar 30, 2009 12:17 PM
Swetech
Exhaust System Topics
Jul 18, 2007 06:50 PM
