getting ready to "push the button"
Old Jan 20, 2013 | 03:14 PM
  #191
traildog's Avatar
traildog
Why does she backfire through the carb when I pull the enrichener?
Old Jan 20, 2013 | 03:15 PM
  #192
V-Twins & Bowties's Avatar
V-Twins & Bowties
If the fuel is not going from the tank to the carb then into the engine it won't run. You could have twenty gallons. Humor me and insure you have full fuel flow to your carb and that it is entering the cylinders. When you post that the plugs are soaked and still no response of firing then move on to next fix.
Old Jan 20, 2013 | 03:18 PM
  #193
traildog's Avatar
traildog
Originally Posted by lownslow
It doesn't take much to open the petcock. When I drain my tank I use a brake vac like the one in the pic. No more than 10-12 in. HG, you don't want to damage the diaphragm.
Hey! I have one of those. Tank is off the bike and drained. I'll try that in a little while.
Old Jan 20, 2013 | 03:23 PM
  #194
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
The Harley manual has a way to check the stock coil with a multimeter.
You might look up your coil and see if there is a similar process on line.
Old Jan 20, 2013 | 03:26 PM
  #195
Doug S's Avatar
Doug S
Did you try ether yet-(please tell me you have)?
Not carb cleaner, that only works if you use a tiny bit, any more and you kill ignition. You have compression, with your hot wire you have plenty of spark so it's not the coil at this point, next is fuel. If your plugs are not wet after cranking it enough to burn up the starter clutch then it aint getting enough fuel. If it fires with ether you know you are on the right track...
Ds
Old Jan 20, 2013 | 03:28 PM
  #196
traildog's Avatar
traildog
Anyone?
  #197
texashillcountry
Dirt don't hurt
I'm guessing you have never had to siphon anything before.
To drain your tank you need about 4 feet of fuel line. Put one end in the tank as close to the bottom as you can. Then suck on the other end till the hose has gas in it then just put the end you sucked on into a gas can sitting on the floor.
This method won't get all the gas out of your tank but it will get 90% of it.
I had to do this a couple of time before I changed my petcock to a non-vacuum operating one.
Old Jan 20, 2013 | 03:30 PM
  #198
texashillcountry
Dirt don't hurt
Coughing through the carb indicates a lean condition.
Old Jan 20, 2013 | 03:52 PM
  #199
traildog's Avatar
traildog
Last time I did THAT, I was tasting fuel for a week......I'll ask my son to do it.......
Actually, she's drained. I'm going to get some ether.
Old Jan 20, 2013 | 03:53 PM
  #200
traildog's Avatar
traildog
As in, not enough fuel?
