Squeak-Squeal-grind in primary after stator replacement
Old Aug 18, 2013 | 09:18 AM
  #31
Millhouse 1340's Avatar
Millhouse 1340
5th Gear
Does anyone have the drive pulley removal tool and sprocket stop tools I can borrow? please PM me
Old Aug 18, 2013 | 09:23 AM
  #32
bluharley's Avatar
bluharley
deleted
Old Aug 18, 2013 | 09:49 AM
  #33
traildog's Avatar
traildog
Originally Posted by bluharley
Maybe you want to remove your number from your post and just request a PM (Private Message). There are trolls.
Too late. Traildog has the number.............. ;-)
Old Aug 18, 2013 | 11:33 AM
  #34
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
All you need to do is go and get you a piece of bar stock from home depo.
Measure a good angel for the bar stock between the two gears in the primary.
Then cut it to length and use it to lock the gears when trying to pull off the compensator and clutch hub nuts. You will have to readjust depending on which nut you are trying to loosen or tighten.
Your 93 should have the splined shaft transmission main shaft and you shouldn't need a puller to get your clutch hub off.
Old Aug 18, 2013 | 11:34 AM
  #35
texashillcountry
Dirt don't hurt
Hey blu you should edit your post to get rid of his phone number.
Old Aug 18, 2013 | 12:41 PM
  #36
KingKahuuna's Avatar
KingKahuuna
2nd Gear
Cool Yikes and Gadzooks
OUCH,
That grinding was nasty, but so glad that you found it.
I hate going on hunts for something that doesn't leave too many clues.
My scoot is an 88 Heritage Softail Classic, and I used to take the scoot to the shop when I had an issue. After getting my beast back, I often found metal shavings, Bolts loose, and the last time it when in, I just wanted the tech to adjust the timing. Bad mistake...
I picked up the beast, and noticed right out of the gate the timing was seriously advanced, and inside the timing cover was a pile of shavings that equaled 1/4 teaspoon full, and adding insult to injury the timing plate cover was caved in as though the guy whacked it with a hammer. The tech finally admitted that he had timed it by ear...exsqueeze me ?
I do all my own work now, and will never take it to a shop again, unless they are willing to let me watch up close every move the dude makes. Tired of spending more when the original idea was to spend less...
Sounds to me like your near to getting back on the road, good luck dude...
Only a Biker knows why a dog sticks his head out of a car window.
Keep the oily side down
KingKahuuna
Attached Thumbnails Squeak-Squeal-grind in primary after stator replacement-sh106814.jpg
Old Aug 18, 2013 | 01:33 PM
  #37
bluharley's Avatar
bluharley
Oops.
Old Aug 24, 2013 | 07:41 AM
  #38
Millhouse 1340
5th Gear
I have it almost put together.
Thanks for all the help!!!
Attached Thumbnails Squeak-Squeal-grind in primary after stator replacement-image.jpg
Old Aug 24, 2013 | 02:47 PM
  #39
miacycles's Avatar
miacycles
Did you replace the shifter shaft seal??? Now is a good time especially if it is an original!!!
John
Chef 17
Aug 21, 2018 07:11 AM
gilmour68
Jul 5, 2018 08:48 PM
1999evo
EVO
11
Apr 7, 2015 04:33 PM
HDDyna2006
Aug 27, 2009 06:39 PM
network
Mar 1, 2008 02:05 PM
