Pulled cam out without aligning timing marks...
Old Oct 9, 2013 | 04:40 PM
zimm's Avatar
zimm
Default Pulled cam out without aligning timing marks...
I pulled the nose cone off without taking the timing cover off. Well the cam pulled out with everything. I still need to drill the rivets and get the cam out of the nose cone. BUT..... obviously the timing marks weren't lined up. What do I do?
Old Oct 9, 2013 | 04:43 PM
Jasper86's Avatar
Jasper86
doesnt matter. cam gear and pinion gear have timing marks that force proper realignment.
cam came out because the rotor cup is screwed to the end of it. did you already have the lifters / lifter blocks out? (id be surprised if it pulled right out with lifters still in there)
Old Oct 9, 2013 | 04:57 PM
zimm's Avatar
zimm
Thanks Jasper, that helps. Nope lifters are still there. I ordered a 12pt socket for the lifter blocks from sears. My 1/4 box wrench is cracked too- so that's useless.
Old Oct 9, 2013 | 05:00 PM
bluharley's Avatar
bluharley
Umm, I hope someone can explain how the cam came out with the lifters still in!?!?!?
Old Oct 9, 2013 | 05:01 PM
zimm's Avatar
zimm
Pushrods were out, in think the cam just came out and
The lifters just moved out of the way.
Old Oct 9, 2013 | 05:08 PM
bluharley's Avatar
bluharley
Oh, ok. Didn't catch the part about the pushrods out!
Old Oct 9, 2013 | 05:21 PM
jsbridgew's Avatar
jsbridgew
like they all said ^^^ ....it's not a catastrophe
Old Oct 9, 2013 | 06:13 PM
zimm's Avatar
zimm
Yup, I pulled the whole top of the motor apart- progress in another thread.
https://www.hdforums.com/forum/evo-c...s-milling.html
Old Oct 9, 2013 | 06:25 PM
lieutenant G's Avatar
lieutenant G
I did the same thing when I pulled my cam the first time. I had to clean everything up to see the "alignment dots." Consider putting in a new breather gear while your in there.
Old Oct 9, 2013 | 06:36 PM
Uncle G.'s Avatar
Uncle G.
Not a problem, really, just turn the pinion shaft with a socket on the nut until the timing mark on the pinion gear is at 12 o'clock. reassemble the cam with its timing mark aligned with the pinion mark. The second mark on the cam aligns with the mark on the breather gear.
With the cam and pushrods out, the engine can be turned to your heart's content without hurting anything. The valves are held closed by the springs.
quigley
Exhaust System Topics
16
Sep 26, 2022 02:09 AM
Meatpants
Shovelhead
May 8, 2017 09:09 PM
Wmitz
Engine Mechanical Topics
May 19, 2014 09:28 PM
dano13208
Mar 17, 2014 05:42 PM
ollscool
Ironhead
Jul 4, 2008 08:58 PM
