3/4 to 1 inch axle verification
OK, Just so everyone knows, I have used the search function on this topic and I believe I'm correct when I assume that I can:
Swap out the 3/4 inch bearings in the 99 wheels for 1 inch bearings and run the 1 inch axle for the 2000 and up lowers. The 1 inch bearings are the same OD and the same thickness as the 3/4 inch bearings.
Am I correct?
Thanks in advance folks!
Am I correct?
Thread: https://www.hdforums.com/forum/softa...e-axle-qs.html
Rotors:
The wife's '99 RK has 11.5 inch rotors on the front, there are also 11.5 inch rotors available for the 84-99 touring models in the JP and Dennis Kirk catalogs.
Lower legs and calipers:
My plan is to use the '00-07 lowers and calipers since, IIRC, HD started using Brembos in '08? Someone can correct me if I'm wrong on this.
Enlarging the bore in the hub for a 1" axle won't be a problem. I have a friend who could enlarge the bore in the wheel for the bearing if necessary
The 99 does have the 3/4 tapered bearings. I understand what you are saying about finding a 1 inch wheel, but I want to run matching wheels front and rear and I have this nice set of RK rims I got nice and cheap. That said I will do some searching and see if there is a 2000-up rim that matches the 99 spoke pattern, but if not, it may be cheaper to open up the bearing bore in the 99 wheel than buying another matched set of wheels.
and either find a axle with a larger head or use SS and make a pair of washers for the outside
I just bought a pair of one season 'take off' fork lowers for $0.99 on Ebay. Yup, 99c plus shipping. They even have their original stickers on them.
Feel kind of guilty towards the seller but no one bid against me. The most I have paid for them is 50, and that was for a completely new, unused pair still in plastic bags.
Add in some 4 pot (Hayes?) or Brembo calipers and it's really cheap, no 2nd question asked upgrade to do.
The later wheel/axle combination is for 25mm, not 1" (25.4mm), however the fork lowers remain the same size. The bosses/threads/bolt end on the two different axles are the same. Therefore, say, a 2002 lower will suit a 2012 Brembo set up.
The clue is in the part numbers which are:
• SLIDER, slider (left)
Part No: 46496-00A
• SLIDER, fork (right)
Part No: 46498-00A
Which means they are the same from 2000 (or 00) upwards to 2013
If you have a Road King with spoked wheels and rims, check for rust and corrosion in the center of the rim as it was common and will fail eventually. The cheapest and easier upgrade for a 3/4" axle would be a similar aged Fatboy solid rear wheel, which would bolt straight in. You won't need to do nor pay for the costs of a swing arm conversion and, as you have bags cover it, visibly it wont matter if two wheel don't match ... and be a hell of lot easier to keep clean.
That way you can spend your money on your preferred version of a front wheel whatever size and design it is, e.g. alloy, rebuilt spoked, 18" etc.
Fatboy wheels on the front take a little more work.
Part No: 46496-00A
Part No: 46498-00A
