Acceleration levels off @ 80mph
Old May 13, 2014 | 09:01 PM
dannyboy048's Avatar
dannyboy048
Stage III
Default Acceleration levels off @ 80mph
HI guys & ladies,
1998 fxd
44,000miles
just put this bike back together i rebuilt it after a friend laid it down
acceleration feels smooth, crisp, and quick until i hit around 80mph then i dont have enough power to pass a semi, it just seems to plateau. i can squeeze a little more out of it but not much more than 85 or so.
thanks for your time and help ML&R
Old May 13, 2014 | 09:21 PM
Spanners39's Avatar
Spanners39
Originally Posted by dannyboy048
HI guys & ladies,
1998 fxd
44,000miles
This can happen if you have a shim under the needle and it gets stuck sideways and jams the needle up from its position in the slide.
Could be blocked air filter, incorrect float height....give it a major service and check all your settings/adjustments are correct and then get back to us.
Old May 13, 2014 | 09:29 PM
johnjzjz's Avatar
johnjzjz
in this rebuild did you happen to add a windscreen maybe
Old May 13, 2014 | 10:29 PM
Kabear's Avatar
Kabear
Assuming it just runs out of gitty-up but continues to run smoothly I would check for a dragging brake.
Easy enough, just take it around the block and stop without using the brakes, get off bike and check brakes for excessive heat, watch out they could be real hot, also feel the wheel hubs and make sure they are also still cool to the touch.
Old May 13, 2014 | 11:26 PM
dannyboy048
Stage III
thanks guys, Ill double check the brakes in the AM, no windscreen was added, and ill take a deeper look into the carb this weekend
Old May 14, 2014 | 05:00 AM
grbrown's Avatar
grbrown
Harleys are over-geared in top, how well does it run in fourth gear?
Old May 14, 2014 | 05:34 AM
Tom84FXST's Avatar
Tom84FXST
Before you tear the carb apart, make sure the petcock screen is not partially clogged.
Old May 14, 2014 | 05:59 AM
Schex's Avatar
Schex
,,, and try it with the gas cap cracked open to eliminate a vent problem.
Old May 14, 2014 | 07:51 AM
RLH3175's Avatar
RLH3175
This gearing calculator for a 96 Ultra may be a little different from your bike, but would be close, keep it in 4th gear longer.
Old May 14, 2014 | 11:21 AM
HarDlife's Avatar
HarDlife
That dyna should have no problem pulling past 80 in 4th or 5th, unless its geared up.
Mine would be tached up pretty high in 4th @ 80.
