ACME and Indian
Old Jul 9, 2014 | 12:23 PM
Richy8302's Avatar
Richy8302
Default ACME and Indian
So I've got this acme choppers wide glide springer I want to put on my 88 FLSTC, I've also got the idea of putting on an indian scout swing arm I found. From what I've found indian pretty much copied HD during the gilroy years, so it should bolt right up. I've got almost everything for the springer except front brake and risers.
What do you guys think? Bad ideas?
Old Jul 9, 2014 | 01:12 PM
Throttle_Jockey's Avatar
Throttle_Jockey
I'm not a springer fan so to each there own. I will say that is a good looking springer.
As for the swing arm I like the idea. I wanted to use one on a softail I'm building but couldn't find one before everything went to PC.
Old Jul 9, 2014 | 03:59 PM
johnjzjz's Avatar
johnjzjz
my guess its a 6 over springer and it does not have a shock so hold on in the corners
now i drove a 12 over when i was a kid so i am not going to tell you what to do BUT pogo bouncing on the Bklyn / queens expressway and the belt parkway was taking your life in your hands back then -
you could consider a front shock it makes all the difference
Old Jul 9, 2014 | 06:31 PM
Tee&Vee's Avatar
Tee&Vee
I went into the Acme factory last fall, pretty sweet shop setup he had and he had some killer (sick for u dyna boys) products for sale. I was about to buy a two over for my heavy Heritage but lucked out with a swap moco find situation. His place is next to the HD dealer a stone's throw from Weir's Beach which is where the debauchery from the bike week is. Worth a visit if you're local.
Post some photos of your project.
Tom
Old Jul 9, 2014 | 11:00 PM
Richy8302's Avatar
Richy8302
I measured my stock FLSTC forks and they are 24 inches the springer is 22 inches, what's the stock HD springer length?
Old Jul 9, 2014 | 11:32 PM
Prot's Avatar
Prot
Why are you wanting to change to that swing arm? What are the benefits of it?
Old Jul 10, 2014 | 11:53 AM
Richy8302's Avatar
Richy8302
Basically for looks, just something diff really. A custom looking swing arm without having to do a wide tire set up.
Old Jul 10, 2014 | 08:02 PM
Tee&Vee's Avatar
Tee&Vee
Amen to that. I like skinny tires too.
scottysalesman
Nov 19, 2017 03:31 PM
Mk1Racer
Sep 15, 2010 09:06 AM
StreetBobbin
Nov 21, 2007 03:47 PM
jmmendez
Nov 16, 2007 01:46 PM
jackyl
Jun 24, 2006 01:48 PM
