What would cause inconsistent spark?
Old Aug 2, 2014 | 12:00 PM
  #41
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Originally Posted by Throttle_Jockey
THC correct sir. With a thunder jet external makes jet changes a lot less hassle
I couldn't agree more.
It is a PITA changing the stock air bleed.
Old Aug 2, 2014 | 05:13 PM
  #42
traildog's Avatar
traildog
Ok, why would I want to change the air bleed?
Old Aug 2, 2014 | 06:04 PM
  #43
texashillcountry
Dirt don't hurt
To change the time the main jet comes in.
Old Aug 2, 2014 | 06:31 PM
  #44
traildog's Avatar
traildog
Got ya. Thanks. I ain't messin with that. Had a nice ride on my freshly washed EVO today.
The problem seems to be solved.
Old Aug 2, 2014 | 10:35 PM
  #45
D_gyver's Avatar
D_gyver
Normally that plug is only removed when a external air bleed is installed. Glad you got it worked out man.
Now THC has a point. Quit intoxicating that thing with sea foam. I hear there is an SFA group , but the first step is admitting you have a problem!!!
that plug is for non S&S air cleaners. some aftermarket air cleaners plug off the bowl vent for the air bleed. if that happens you remove the plug so it can get air there's a small cotton filter kit that can be screwed into it.
Old Aug 3, 2014 | 12:07 PM
  #46
LowriderHarold's Avatar
LowriderHarold
Yep. When I ran a S&S, I put Zipper's Max Flow ac kit on, & backing plate covers vent hole on face of carb. Instruction's tell you about that, & tell you to remove the plug. That cotton filter kit sounds like a good idea to keep trash out of the float bowl.
Ride Safe,
Harold
Old Aug 3, 2014 | 12:13 PM
  #47
texashillcountry
Dirt don't hurt
Got a part number?
Old Aug 4, 2014 | 12:03 AM
  #48
D_gyver's Avatar
D_gyver
Got a part number?
not sure who makes it it was given to me by a local shop ill ask them where they got it and let you know
Old Aug 4, 2014 | 06:07 AM
  #49
texashillcountry
Dirt don't hurt
Thanks.
Old Aug 5, 2014 | 05:51 PM
  #50
D_gyver's Avatar
D_gyver
Got a part number?
ok talked to them today there is no part number they make them in house
and here's how they do it its a fuel filter for a echo chain saw. they run a die over the nipple so it will screw in. they said they seen a few guys using them on drag bikes with a velocity stacks. and thought it was a good idea. they also said it only works on .100 air bleeds or smaller any larger and it wont get enough air.
