Moving to Germany, Need quiet pipes for registration
Old Mar 29, 2017 | 03:10 PM
Professor317's Avatar
Professor317
Stage II
Default Moving to Germany, Need quiet pipes for registration
Greetings!
So I'm a military guy, headed to Germany for a couple of years. I'll be taking my 2000 softail with me. Right now it has V&H True Duals with baffles installed and its pretty loud. I'm told the german equivalent of the DMV does a decibel test to register the bike and if you're higher than 95db, you're out of luck.
I'd like to get some very quiet baffles to quickly install just before the inspection and remove immediately after. I'm also open to any other solution you all might recommend. Many thanks
- professor
Old Apr 3, 2017 | 04:10 PM
grbrown's Avatar
grbrown
Exclamation
I have US family who were in the military for many years, serving in Germany. Check things out more thoroughly as I will be most surprised if you have to register locally as soon as you get there. There is usually a period of grace for a while, possibly 6 months. Same applies for any car you take. As a regular visitor from the UK we don't have to register there while on holiday! Nor should you. IMHO you should have ample time after you get there to establish what you need to do. Alternatively you could simply fit a stock US system before you go.
Old Apr 11, 2017 | 01:37 PM
David B. Moser's Avatar
David B. Moser
Stage I
Default Cheap fix
I live near Kaiserslautern. I bought and installed quiet baffles from V&H for my 2005 Springer. It tested out at 95.9db and failed. I found a shop close to here that sold me used stock slip-ons for €50. It's called Ghetto Blasters if you end up in K-Town.
Old Apr 11, 2017 | 03:20 PM
5150northrider's Avatar
5150northrider
Dealerships might have some ome pipes that fit, if so they should almost give them to you if you know them. They dont really need them after they change out the pipes on stock new bikes
Old Apr 12, 2017 | 03:33 AM
german ladyrider's Avatar
german ladyrider
Moderator
Originally Posted by Professor317
Greetings!
- professor
Check out ebay.de, the German word for baffles is Auspuff. Or join us on Facebook in the Group "English speaking motorcycle riders in Germany". You might find a lot of helpful Information there.
Old Apr 18, 2017 | 12:00 PM
FXR_Hamster's Avatar
FXR_Hamster
Did two tours in Germany (90-94, & 2010 -2013)with three HDs (93, 2004, and a 2012, I bought through US Military Vehicle Sales in Ramstein AFB. Check with Mil Sales Reps as they might have some insight, or you might have some special allowances for US Spec vehicles due to SOFA (Status Of Forces Agreement) due to NATO and US Mil/German vehicle registrations. Worth asking your base vehicle registration office. Only got harassed once by local Police on my last tour while out riding and they left us alone when we produced our NATO vehicle registrations for our bikes, and Military licenses.
German TuV (German Government Inspection and Governing Department) was really strict up until the late 90's but things have gotten a bit less restrictive.
Also I knew a few guys that ran Supertrapp systems that were compliant owing to the fact they could regulate the noise levels via the Discs of that particular exhaust system.
One newer exhaust system ( I think a dutch company introduced was a controllable internal exhaust valve system http://jekillandhyde.com/en_global/products
System allows you to control the db levels , but it is heavy as it has state of the art stainless internals and it is pricey but have heard it in person and it works ...flic of a switch and exhaust goes from loud to quiet (not sure about effects on tune or tuner, EFI, but for slips ons it works. Heard the system is cheaper to purchase in North America than in Europe for initial costs.
Hope this helps and enjoy the riding around Europe, as there are some awesome roads.
SE
Old Apr 18, 2017 | 12:03 PM
grbrown's Avatar
grbrown
Thumbs up
They were at a recent UK bike show and their system certainly looks good and very well made.
Old May 19, 2017 | 12:51 AM
Jay Flynn's Avatar
Jay Flynn
Stage II
When you register your bike you will be given 30 day temp tags. Within that 30 days you have to get it inspected. Once it passes you will go back to vehicle registration and change out to a permanent registration that is good for a year. Cost will be 35 dollars per year. Every year it will need to be inspected. A couple of point;
1. The german police will stop you for a loud exhaust and will test it on the side of the road. The fine gets expensive quick and they can revoke your driving privileges. My opinion is to get a set of stock pipes and run them while stationed over here.
2. German LP's are much bigger in size. You can request an exception to policy that will get you a smaller plate. If you want, send me a PM and I will get you the email address and requirements for submitting the exception. I have it for my bike and the smallest plate we can get still needed to be bent to fit on the back of my Electra Glide.
3. AER 190-1 covers license and registration requirements here in USAREUR. look in there if you need specifics or again you can send me a PM and I will try and help you out.
Old May 19, 2017 | 03:48 AM
Ron750's Avatar
Ron750
Is your bike carburatored, or fuel injected? Was it rejetted, flashed or have a fuel management system? They may have to be recalibrated if you put stock pipes on.
I have never been to Germany but I suspect the post about being stopped by Police is correct. Good luck.
G9803
Jul 16, 2014 10:18 PM
LDB415
Sep 9, 2012 11:17 PM
Spartaman
Aug 22, 2009 09:39 AM
LowBoy08
Apr 8, 2009 01:07 AM
PoorBoy
Jan 13, 2008 04:13 PM
