oil pump alignment tool
Old Jan 30, 2008 | 04:30 PM
dgriffith's Avatar
dgriffith
Default RE: oil pump alignment tool
No dawg, It's something I'll be doing next month when I get home from this job I'm on now. I just wanted to have all the parts and tools ready when the time comes. No big rush. Thanks for asking Dan
Old Jan 30, 2008 | 04:35 PM
rbabos's Avatar
rbabos
If you can pm me with your emailaddress , I can send it to you ?
Ron
Old Jan 30, 2008 | 04:38 PM
ajayrk's Avatar
ajayrk
One other option is to email me and let me capture your email address and I will attach the file to an email to you. You will need adobe reader to view it. Free downloads for the reader are on the net.
Old Jan 30, 2008 | 05:19 PM
dgriffith's Avatar
dgriffith
Thanks to all of you, for all your help. I hope I didn't offend anyone, I just want to have everything I need to do the job right the first time. Next question will be , Which brand of adjustable push rods is better or best bang for the buck. thanks again, Dan
Old Jan 30, 2008 | 05:25 PM
pittguy's Avatar
pittguy
With out the tapered tools you install all 4 oil pump bolts, very lightly seat them rotate the motor, trans in 5th or 6th depending on yr,spark plugs out, 2 or 3 times, snug bolts a little more, turn motor 2 or 3 times, tighten more, turn more, tighten more, until you get tofinal tq.
Old Jan 30, 2008 | 05:50 PM
ajayrk's Avatar
ajayrk
The best bang for the buck is the Harley Screaming Eagle kit. It comes with the pushrods, shorter tubes, longer clips and the o-rings. It is best to bore out the pushrod tubes to .610 so the oversize adjustable pushrods won't rub.
The new S/E tapered pushrod should clear without boring the tubes, but they cost more and don't come as a kit.
Old Jan 31, 2008 | 07:46 AM
Neckball's Avatar
Neckball
Where is the clearance issue, is it at the top of the tube? I'm installing a set of the SE adjustables this weekend, just want to know what to look for.
Old Feb 2, 2008 | 08:43 AM
ajayrk's Avatar
ajayrk
Most of the clearance problems is at the top where the shoulder is formed to seal the o-ring at the head. An inside collar results reducing the inside diameter. Removing the collar may be all that is necessary and that could be done with a die grinder. Just match the major diameter.
Old Feb 2, 2008 | 10:10 PM
producer's Avatar
producer
I bought mine on ebay. I could have made mine too, but for 15 bones and the fact that they are heat treated, why would I want to give myself the head ache.
Little Mike
Engine Mechanical Topics
38
Feb 8, 2017 06:00 AM
Datankid069
Apr 9, 2013 10:07 AM
BadPiggy
Mar 9, 2008 04:38 AM
hotrod351
EVO
11
Aug 11, 2007 05:13 PM
mark2004RK
Mar 12, 2007 06:44 PM
