Stage 1 defined???
However, from what I have read, there are parts or systems out there that will void the H-D warranty. Is there a list? I have a two week old FLHRC and do not want to have warranty issues.
Also, I have read about the Magnuson/Moss decision. However, I live in California. I would have to guess that making changes, such as getting rid of the cat, would not be included in the M/M decision because it is an illegal modification. As such, would such an improvement void the warranty?
I have been considering the V&H PowerDual. Along with the V02 Naked w/ the stock cover. (I happen to like the stock look.) I have also been considering finding some stock slip ons (Again, I like the stock look) and removing the baffles and installing them. Or, V&H slip ons. I am still working on this decision. With these modifications I believe I would need a way to correct the fuel mixture. I am not interested in spending a lot of money having H-D dyno and adjust the bike if a bolt on unit like the FuelPak will do the job. I am new to this and so I am also looking into Fuel Moto. Do they not also make a way to adjust the mixture for optimum performance?
Anyway, after this long winded introduction.... And comments? Advice?
You can see my bikes info in my signature below.
You will need some fuel management system with your Stage I upgrade. The head pipes are fine and a good set of aftermarket slip ons, like the V&H units you mention, or Rush or Cycle Shack which are also good equipment. The SE air filter upgragde and the new exhaust will require fuel adjustment and the motor will be running leaner than in stock configuration. You don't need a fuel manaement system that will require dyno time for a Stage I upgrade. The operative word is NEED; there is no substitute for a dyno tune but you can manage a Stage I upgrade with one of the "pot" type systems like the Techlusion DFO. Very user friendly and many have used this system on Stage I uprades; a better option than the V&H Fuelpak, IMHO.
Fuel Moto does have some packages that are built around the DynoJet PC tuner. They have a library of "maps" that can be downloaded to your computer and you can upload them to the tuner. The PC tuner is a "piggy back" system that tricks the ECM into sending the required fuel to the motor. Not a bad way to go but I would go the DFO route because you can tune yourself. If the FuelMoto map is not just right, you will have to download/upload until it is, or hit the dyno.
I can't advise you on the cat but from what I read and hear, removing it doesn't really add much to the performance but does increase the volume of the exhaust. I do know that it can be removed without any indication from the outside that it has been removed. Whatever you do, don't run the slipons without the baffles.
http://albums.phanfare.com/isolated/...945184_5528623
You just need to spend some time on the internet, educate yourself a little and continue using the forum as a resource as you gain knowledge. Just don't get in a hurry; don't pull the trigger until you are sure about your modifications.
One of the reasons I am here is for the education from guys, and gals, who have more info than I do.
If you want to know about residential remodeling I am your man. And I am not bad with Ford diesels. But, Harley Davidsons.... I am just beginning.
Unfortunately your link does not seem to work.
Thanks again for the feedback.
http://albums.phanfare.com/isolated/...5184_5528623ll
You can also follow the below link to a thread where I posted the original link and get some additional info on cat removal. I am sure you won't be the only California rider that has removed the cat.
https://www.hdforums.com/forum/touri...ing-cat-2.html
http://albums.phanfare.com/isolated/...5528623ll.html
Just needed to tack on a dot html.
Though I like to looks of the V&H PowerDuels X pipe.
I will look into the DFO.
Thanks for the info.
Now for an air cleaner.... I like the stock look and I am not trying to get the bike to stand up on end. Just free up some horses.
Why not run slip ons w/out baffles?
So IMHO a dyno tune, along with any necessary downloaded revised maps, is pretty essential, to unravel those things I mention and optimise performance. No two bikes are the same and the options of bolt-on stuff are widely varied. Reduced gearing would also be a worthwhile improvement, although requires a bit more spanner work.
