I thought it was pinging
Old Sep 27, 2013 | 07:34 PM
mnccnm's Avatar
mnccnm
Default I thought it was pinging
98 Heritage. When rolling into the throttle after shifting to 2nd and 3rd, there is a different sound coming from sounds like the left side of the motor. It does it until rpms and speed pick up. I thought maybe it was a ping, but it really doesn't have that metallic sound I'm used to hearing from a ping. Just in case though I replaced the vacuum lines, plugs and plug wires. I don't have a vacuum gauge so I couldn't check what vacuum the VOES was switching, but I could verify it was switching. I also filled it with some 100 octane.
Still does it.
The bike seems to run great except an occasional backfire on start up when warm, (another post).
Could it possibly be pinging on 100 octane, and otherwise run great?
Any thoughts?
Old Sep 27, 2013 | 07:36 PM
perki48's Avatar
perki48
Check for manifold leaks.
Old Sep 27, 2013 | 08:12 PM
mnccnm's Avatar
mnccnm
Exhaust?
Intake leaks would make it run like crap right?
Old Sep 27, 2013 | 08:16 PM
aces&8s's Avatar
aces&8s
Intake leak will make it Idle high and low.... Ping can be fixed usually by retarding ignition a little bit. Your ignition is too advanced.
Old Sep 27, 2013 | 08:21 PM
perki48's Avatar
perki48
Originally Posted by mnccnm
Exhaust?
Not always, but it will make it run lean and lean causes ping. As does timing which has been mentioned.
Old Sep 27, 2013 | 08:35 PM
aces&8s's Avatar
aces&8s
Leaking intake wont make it run too badly but it will Idle high and low when the ingine is running temp. Spray carb cleaner around intake while Ideling. if intake is leaking it will effect Idle. I would bet your timing is too advanced.
Old Oct 5, 2013 | 03:48 PM
mnccnm's Avatar
mnccnm
Well, the timing wasn't off, but both intakes were leaking. I replaced both intake seals and the carb. seal and so far so good!
Old Oct 5, 2013 | 06:57 PM
perki48's Avatar
perki48
Thanks for the update.
doc308
Shovelhead
Aug 17, 2018 12:50 PM
Proud Marine Dad
EVO
Apr 1, 2013 08:13 PM
Ironkidzsled
Ironhead
34
Apr 27, 2010 10:36 AM
graultytc88
Apr 28, 2009 07:23 AM
FandA M
Jan 11, 2008 11:07 PM
