Banging my head 45 won’t start
Old Feb 26, 2023 | 06:12 PM
  #101
Scotty p's Avatar
Scotty p
Ok, for at least 5 times now I checked compression on each cylinder , 62 lbs on each cylinder.
fresh fuel, high octane chevron.
Timing on mark, Fully advanced on circuit timer used test light to ensure accuracy ( dead on )
checked both intake and exhaust valve for full movement. ( note new valves and valves springs.
And as said running totally out of ideas!!!
Does anyone believe in a possessed bike?😕
If not I do believe I’ve got on.
Old Feb 28, 2023 | 06:58 AM
  #102
johnjzjz's Avatar
johnjzjz
Ok i am going to this idea
not enough advance in the distributor - no one asked how you set the advance - loosen the clamp at full advance turn it counterclockwise dist even more like 3/8 of an inch - see if when kicking it the pedal chuckles < from too much timing - try and start it
when they are retarded to much they wont start - you can with a 45 leave the timing at full advance un like a sporty that will snap your ankle doing that it does not care and does fire off easy - we set the advance from the back of the timing hole with the line as it makes it just a bit smoother to start and run and we leave the advance full all the time unless it chuckles when kicking then turn the distributor clockwise just a bit try again if it does not chuckle then thats the spot to start it at
Old Feb 28, 2023 | 10:45 AM
  #103
Scotty p's Avatar
Scotty p
I hear what you’re saying about the timing advance. I just reset the timing like I have many many times.
I’ve had it set so well in the past that I didn’t even have to kick it very hard to get her running.
Cold or hot, just one little kick and BAM !! Running like a champ!! And than it just stop!
Valves working correctly, and getting spark.
I’ll check and recheck the timing again!
Big cigar when I find it.
thanks.
Old Feb 28, 2023 | 02:36 PM
  #104
johnjzjz's Avatar
johnjzjz
I have had in the past couple years the distributor looses it ground after it is kicked - cant find the answer but we add a ground to the distributor
Old Feb 28, 2023 | 03:49 PM
  #105
Scotty p's Avatar
Scotty p
So when you say added a ground to distributor , are talking about adding a wire from the base to the frame?
Old Feb 28, 2023 | 04:11 PM
  #106
hellonewman's Avatar
hellonewman
You could be losing your ground through the engine to the frame if the frame mounts weren't bare metal. I would run a wire from the distributor (timer) to the frame. Im assuming the battery connection are good as is the battery?
Old Feb 28, 2023 | 04:42 PM
  #107
Scotty p's Avatar
Scotty p
I recently pulled the motor, after having this issue and made sure the fame and motor had clean surfaces for a good ground!
The frustrating thing is that I’ve checked and recheck everything on this machine but ha ha moment yet!!!
I’ll try a wire from timer to fame to see what happens!
Story /issue continues….
Old Mar 5, 2023 | 02:07 PM
  #108
Scotty p's Avatar
Scotty p
So here’s what I’m puzzled about.
after putting my hand over the carb, hand chocking it and kicking many times I noticed the plugs are dry!!
So I would think that flooding out a motor would lead to wet plugs.
like I’ve said, I replaced the pistons, rings, valves and springs. I’ve got 62psi on each cylinder, getting some popping but no start and plugs not wet!
puzzled again.
Ok up date:
So I just dump some fuel down the carb, and clamped a ground to the circuit timer and she started.
So I’m thinking it was a grounding issue, so just to test the waters I removed the ground wire and she started!!!
Now I’m totally confused what’s going on, I did notice a lot of force coming out of carb when trying to start still not sure why this all started in the first place!
Anyone have any clue?
Old Mar 5, 2023 | 04:27 PM
  #109
tasturbo86's Avatar
tasturbo86
Did she keep running?
When I cover choke it with my hand, my hand gets wet.
Old Mar 5, 2023 | 05:44 PM
  #110
johnjzjz's Avatar
johnjzjz
Seen that more then once with a ground - after it started and the temp came up just a bit and the parts were moving running the ground came back
this is a very common issue with Indians as the dist bushing wears just a bit then the ground going away
a 45 i have done an added ground - i turned the dist around 180 so i did not have to remove it drilled a hole 8 /32 or 10/32 tap and attach a ground wire ran it to the generator nut under the cover
