Frame/Suspension/Front End/Brakes Discussions for your ride comfort and braking power.
Lowering a Deuce Part No. SRES24?
Old Feb 18, 2007 | 07:20 PM
FL DEUCE's Avatar
FL DEUCE
Default Lowering a Deuce Part No. SRES24?
In my service manual it says i need "Part No. SRES24" to gain access to shock bolt. I haven't seen anyone who has lowered their bike say anything about this tool which costs $45. What did you use instead of this tool? I'm thinking this just another way to suck every dollar we have out of us.
Thanks
Old Feb 19, 2007 | 03:40 PM
Kong's Avatar
Kong
Default RE: Lowering a Deuce Part No. SRES24?
I thought I answered this earlier.
No, you don't need any special wrench, but you do need to lift the bike. You can easily get a box wrench on the bolts on each side (little tighter on the right) and then get yourfoot on it to breake it loose from the locktite. After that they come off by fingers. Front nuts are pretty much the same. I use a Sears red jack and I don't have any problem at all getting to my shock bolts.
The actual lowering is pretty easy too. Just be careful with whatever jig you end up using to compress the spring. A 4" section of inch and a quarter water pipe is necessary along with about 4 inches of press travel as well.
JAE88
Apr 17, 2012 10:37 AM
DMC1
Jul 22, 2011 11:04 PM
travis dasher
Jan 10, 2010 08:38 PM
thaasjr
Aug 23, 2009 05:25 PM
FL DEUCE
Feb 18, 2007 10:06 PM
