will stage 1 upgrade make a noticeable difference ?
A good Stage I will give you more torque, not just in the low RPM's, but all the way thru the RPM band, will increase your MPG, will run cooler, and will increase the longevity of the engine.
Here is a Dyno Chart of a good Stage I on a Softail Heritage-
You can see more info on the difference between most Stage I's, and good Stage I's at this LINK
It will run better, sound better and exhaust better. It will also run cooler, extending the life of the engine.
A cam can come later.
Make sure to at least do a Dyno tune, as it will reveal any problems that might arise from the install.
I don't think I would want my fully loaded touring bike to have 1:1 throttle response when doing slow speed first gear maneuvers in a busy parking lot. Although setting it to 1:1 maybe worth an experiment when I get home and unload it.
But when I added the Andrews 26H cam,, THAT made a MAJOR difference in low end TQ....
I know the 103 produces about the same stock STG 1 as my Cammed 96''er so I'd have to ride a newer bike to really give a better answer.
But as I stated above, there are many different implementations of Stage I, and some, as you've experienced, don't do much.
As stated, before doing cams, you need to do a Stage I. After doing the Stage I, you might have all that you want power wise and not need to go further (with cams).
DKCustomProducts.com
Ok, thankyou ! the dyno tune must be the go, as compared to just a tune download
95% of the time this is because of the following-
The vast majority of Stage I's utilize an air cleaner that pushes the crankcase blowby/pressure back into the combustion chambers.
This builds up carbon on the pistons (see pics below), which increases the compression. The ECM sees that this increased compression, and carbon deposits, is getting close to causing the bike to ping/predetonate. When the ECM sees that predetonation is close to occurring, it will retard the timing to prevent damage. In retarding the timing, MPG goes down, power goes down and heat goes up.
Many will take their bike in and complain of poor MPG, poor power, and pay, AGAIN, to have the bike dyno tuned. This will improve the performance, but only for another 5k to 10k miles, during which the same cycle re-occurs because of even more carbon build-up.
The solution is to get an air cleaner that vents externally (see LINK), or to convert the current air cleaner to vent externally (see LINK).
There are many other factors that differentiate a bad or mediocre Stage I from a Good Stage I, you can see info on the all the differences on the bottom half of this INFO PAGE.
