How do you clean a cast grey engine?
Old Feb 1, 2017 | 09:04 AM
Kenny94945's Avatar
Kenny94945
FWIW I have never had any luck with cleaning the grey on my 1200N.
Maybe S100 will work?
(I have tried many other products, including most listed above, to no avail)
I can add, if you drop oil, wax or any fluid onto the grey color, remove it right away.
I also believe Harley sells a spray can of textured grey paint for a color match/ repaint if need be.
Good luck.
Old Feb 1, 2017 | 09:13 AM
roadkinglobo's Avatar
roadkinglobo
Originally Posted by 97stalker
Mates, just bought this 1989 FXRS H-D Marlboro Man replibike. I have many bikes but this is my 1st with the cast grey motor/block. It's a little cruddy looking. What's best way to clean it up nice?
S100 spray; let sit for ten min; hose off; let dry
then follow-up with HD Engine brite spray - done. Go riding!
Old Feb 1, 2017 | 10:46 AM
boston jim's Avatar
boston jim
Contact IB Sales to have your account opened
I was a Big Fan of S100, reg & gel, for years, should have bought stock in the German Co.! I have custom Sun Spoke Aluminum Wheels, everything stains them! Then I discovered Simple Green, my wheels shine, spray & rinse, I couldn't believe it, as Good, if not better than S100, for 1/10 the money!
Old Feb 1, 2017 | 10:52 AM
adm's Avatar
adm
Originally Posted by Captainrichwine
Awesome bike man! Not trying to thread jack but do you guys know if the s100 will work on black wrinkle cases too?
It works great on wrinkle black!
Old Feb 1, 2017 | 11:56 AM
Geoff's Avatar
Geoff
Simple Green and a stiff bristle brush.
S100 works, but it's much more expensive than Simple Green. It also streaks if you don't use enough rinse water.
Old Feb 1, 2017 | 12:19 PM
NORTY FLATZ's Avatar
NORTY FLATZ
Muratic acid. You didn't hear this from me...
Too many bad things can happen with this...
Old Feb 1, 2017 | 12:34 PM
Geoff's Avatar
Geoff
I used to clean the cases on a BMW boxer with muratic acid. Absolutely nothing worked better. You have to be very careful. The acid must be thoroughly rinsed immediately after application or it will streak.
MysticPurple
General Topics/Tech Tips
Aug 24, 2017 08:02 AM
broziff
Detailing
14
Apr 5, 2017 12:32 PM
StanfordMan
Sep 13, 2010 11:57 AM
rocknrod
Jan 1, 2008 12:34 PM
customsoftail200
Detailing
Jan 17, 2007 05:21 AM
