Vacuum operated switch
Old Aug 12, 2018 | 06:30 AM
Bill#'s Avatar
Bill#
Stage III
Default Vacuum operated switch
1985 FLHTC. Looking at some of these switch's. They all look the same. But in the description It has 3" HG activation, 5" HG and 6" HG. What is this? Does it make a difference what one is used?
Thanks
Old Aug 12, 2018 | 08:12 AM
nvbirdman's Avatar
nvbirdman
Don't know the difference between 3, 5, and 6, but HG is the symbol for mercury. These are mercury switches, not vacuum.
Old Aug 12, 2018 | 08:31 AM
multihdrdr's Avatar
multihdrdr
They're Vacuum Switches rated in inches of Hg (inches of Mercury) for activation ... Does this vacuum gauge look familiar?
Toypuller's Avatar
Toypuller
Inches of Hg is a term, for the amount of negative pressure, it will take to operate the vacuum switch.
Vacuum is measured in Hg. Maximum is 30. So your switches would take whatever the number correlates too.
Larger the number= more vacuum pressure.
Not mercury switches, those take mecury to make an electrical connection, like old style thermostats.
when measuring vacuum, Mercury is the standard of measurement, as in how much negative pressure to pull a column of mercury to a height of a specified number of inches.
Old Aug 12, 2018 | 08:52 AM
hardheaded's Avatar
hardheaded
These vaccum switchs control the spark advance on your bike. Buy the correct one for your application or you may encounter spark knock.
Old Aug 12, 2018 | 09:08 AM
RDHIGH's Avatar
RDHIGH
Yeah- these vacuum switches (VOES) are used by your ignition to determine load, and advance or retard the timing accordingly. You can order any one you want- if you have a vacuum tool (pistol type vacuum pump with a guage)- you can remove the silicone plug on the voes switch- using a small screwdriver- you can adjust the level of vacuum when the switch activates- then just seal up the switch with new silicone.
Old Aug 12, 2018 | 10:44 AM
Uncle G.'s Avatar
Uncle G.
The service manual for your bike should tell you which to use.
Old Aug 12, 2018 | 11:21 AM
RDHIGH's Avatar
RDHIGH
Voes for FLTS= 5 TO 6 IN/HG
Voes for FXR= 3.5 TO 4.5 IN/HG
the difference is in the weight of the bikes.
Old Aug 12, 2018 | 12:03 PM
01fxdxt's Avatar
01fxdxt
click this...
What is VOES?
Old Aug 12, 2018 | 12:51 PM
RDHIGH's Avatar
RDHIGH
Vacuum Operated Electric Switch. Read earlier posts to explain.
SoCalDyna2015
Electrical/Lighting/Alarm
Jun 21, 2019 11:46 PM
mmatthews62
Sep 6, 2018 08:28 PM
Hey Man
Jul 7, 2018 12:15 AM
EasternSP
2014-2024 Touring Models
Jun 19, 2018 03:26 PM
ThisIsCrazy
Sep 10, 2013 09:48 PM
