Help!
Old Oct 13, 2018 | 07:33 PM
Wilsons_mail's Avatar
Wilsons_mail
1st Gear
Default Help!
I own a 2009 flhtcu Electra glide ultra classic. I am supposed to go riding tomorrow with a small group of friends. Today I detailed my bike and took to off trickle charge. Had to replace my battery as it has gone bad on me, fortunately under warranty. As I was installing the new battery I cranked up the bike to get the fuel pumping before I got the seat back on and the wiring set in place under the seat. As it started up and I began to move the wires and put the seat back on the bike lost idle throttle and stalled out. As I cranked it back up, the wires moving around I found that it gained idle throttle back but the actual throttle didn’t work at all on the handle. I got it working as I put the seat back on but why would t do that. Should I be worried not to go riding tomorrow?
Old Oct 13, 2018 | 08:04 PM
Ragtop's Avatar
Ragtop
Sounds like your battery connections are loose.
Old Oct 13, 2018 | 08:05 PM
Wilsons_mail
1st Gear
it almost feels like the computer board on top of the battery is shorting out- the battery cables are on tight
Old Oct 13, 2018 | 08:18 PM
Wilsons_mail
1st Gear
The bike stayed on but had zero throttle until I moved the wires back overtop of the battery
Old Oct 13, 2018 | 08:33 PM
GalvTexGuy's Avatar
GalvTexGuy
Did you try narrowing down which wires and/or harness you were moving that was causing the problems? It may just be a loose connection. Covering up the problem won’t make it go away.
Old Oct 13, 2018 | 09:03 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
Connection to the ECM loose or dirty?
Old Oct 14, 2018 | 10:14 AM
big- mike's Avatar
big- mike
Take a deep breath and relax after detailing maybe water got in a connection take it back apart and check all the connections something is loose I would also use dielectric grease on every connection including the one on the left side of the throttle body
Old Oct 14, 2018 | 11:44 AM
DanHappy's Avatar
DanHappy
What I was thinking.
Op, get it running and move one wire at a time till the motor wants to die. Note it. Then keep going on all the other wires. The marked ones are the ones you need to look at. Once that is done, check over the rest to make sure they all are good. When done, while it is running, move the wires. Hopefully it does not fail.
Yobnayr
Electrical/Lighting/Alarm
Apr 12, 2022 01:30 PM
Centex1991
Aug 16, 2018 11:52 AM
Jace Treat
Jun 19, 2018 04:51 PM
Cozz
May 19, 2018 09:02 PM
clyles
Oct 4, 2014 06:57 PM
