Using the PIN code to deactivate the security system
I am trying to use the PIN code to deactivate the security system. I have a FOB now but in case of emergency I need to be able to use the PIN code to deactivate the security system.
The system has a installed pin code and with a FOB present I can display and change it with no problem. I have tested other functions of the module with no apparent failures.
The FOB is good with a new battery but should not come into play since the PIN is designed to disable the system w/o a FOB present.
Incidentally I originally assumed the security system module was bad when I first encountered the issue so I ordered and installed a second one - 68922-00D. This did not fix the problem.
This system has been on the bike for maybe 15 years and used to work. I just decided to try the PIN method of deactivation to verify it is still working. which to my surprise does not.
Here is what happens when I attempt to use the PIN method of security system disablement.
.These procedures are straight from the Owners manual.
1. The security system is enabled to start
2. Ignition switch to ACC
3. Press and hold both turn signals
4. I immediately get a warning BEEP followed by a 2-3 second pause
5. followed by a second warning beep followed by a 2-3 second pause
6. Then all hell breaks loose not allowing me to enter the PIN code.
Anyone have any words of wisdom as to what I could be doing wrong and what I should to correct the problem?
Try not sitting on the bike, stand beside it so you are not moving the bike when trying to enter the code. Any movement will set the alarm off even when using the security code instead of the fob.
It's a very tedious task. As for what you might have going on - you have to do the functions fast. You have to pay total attention to the light symbol on the tank panel - not the blinkers. Trying to watch the blinkers and all the crap they are doing will mess you up.
https://www.hdforums.com/forum/gener...ity-alarm.html
