Caliper rebuild
Old Apr 22, 2024 | 12:13 PM
jp0469's Avatar
jp0469
Default Caliper rebuild
I'm about to rebuild the front calipers on my Road King due to some stickiness. What tricks are there for not having all the brake fluid leak out at the banjo fitting once the caliper is removed? I saw a video where a guy put an 8mm bolt through the banjo fitting with a washer on each side and a nut to seal it off. However, it still leaks; just a little slower. I was thinking maybe a scrap piece of hose that is slightly larger than the ID of the banjo fitting. Forcing it in should hold back the fluid?
Old Apr 22, 2024 | 01:15 PM
GOGOBECK's Avatar
GOGOBECK
My “Mighty Vac” came with some round tapered rubber plugs. For years I wondered why they came with the vacuum pump until I needed to remove a caliper.
I think you can find them at most hardware or home improvement stores.
You could also shape a wine cork for the task!
Old Apr 22, 2024 | 01:46 PM
jp0469's Avatar
jp0469
Good suggestions. I have a knock off Harbor Freight Mighty Vac and it did come with some extra bits. Lowes or Home Depot might also have some random tapered plugs that could work.
Old Apr 23, 2024 | 07:42 AM
LQQK_OUT's Avatar
LQQK_OUT
Pickup an assortment of vacuum caps at an auto store and use one of them to plug the banjo bolt.
Old Apr 23, 2024 | 08:21 AM
Crazy's Avatar
Crazy
I just let the old fluid drain into a container. I figured it I was rebuilding the calipers anyway I wanted a completely flushed system with completely new fluid when I was done.
Old Apr 23, 2024 | 09:21 AM
jp0469's Avatar
jp0469
I considered that too but I'd prefer to use new fluid to flush out the old without introducing any air into the system. Much easier to bleed that way.
Old Apr 26, 2024 | 08:41 PM
sab4's Avatar
sab4
5th Gear
So what did you end up doing?
Old Apr 29, 2024 | 10:45 AM
jp0469's Avatar
jp0469
Nothing yet. I haven't had a chance to start this little project.
Old Apr 30, 2024 | 02:05 PM
ridingout's Avatar
ridingout
I use a nut and bolt with a o ring on both sides to seal the hose.
Old Apr 30, 2024 | 02:32 PM
Uncle G.'s Avatar
Uncle G.
Once you’ve disconnected the caliper you’ve already introduced air into the system. There’s no way to avoid it. Even if you could block the line there wlll be air in the caliper when you reassemble the brake line and bubbles will rise up the line.
nlrnight
Mar 4, 2024 07:53 AM
SmittyFXDL
Feb 18, 2019 05:15 PM
jeremy2854
Mar 24, 2014 11:35 PM
Droop
Apr 30, 2010 05:57 AM
broadwayjoe
Aug 22, 2007 08:21 AM
