oil comming out of carb
if it wasn't sitting then that's an indicator of a venting problem, and could have any one of several different causes.
some of them are more serious than others.
start with checking your oil level, and making sure you don't have too much oil in the bike.
if it's a minor amount of oil leaking, you could either ignore it ( and keep cleaning it ) or get some sort of aftermarket valve that attaches to the vent hole to prevent air from entering the venting system on the upstroke, this creates lower air pressure within the motor and helps keep the oil in.
S&S makes a reed valve that can help on some bikes, if it's not a softail.
if it's more serious, have a mechanic look at it, in really bad cases it could indicate a failing oil pump or worse.
I am new to bikes. I noticed that there was a bit of oil splattered on my pipes and it looks like it came from the carb. Is that something I should worry about?
you will need someone with EVO 1340 engine experience, I'm almost certain thats what engine you have. One trick I've heard of is to remove some oil out of your oil tank it might be overfilled. If its wet sumping, oil draining back down into the crankcase, Ithink there is a check valve leaking back, a good independent shop can help you out on this one. The crankcase on Harley's is called a dry sump because your motor oil is stored in a tank below your seat and is pumped thru your engine when its running.
have you done any mods to yer bike lately. Changed yer oil or anything.
). You are not leaking enough oil to hurt anything and the pad will soak up what you are losing so you don't make a mess on the pipes.Bill
