Speedometer Issue
Old Feb 18, 2010 | 07:58 PM
jlferguson's Avatar
jlferguson
5th Gear
Default Speedometer Issue
I hope somebody out there can help me. I ride a 2008 Road Glide. A couple of weeks ago my speedometer started acting up. I will be riding along and the speedo just quits. It may stay on zero for 2 seconds or it may stay there for 15 or 20 seconds. Sometimes it doesn't even get to zero before it "catches" and starts working again. I have looked and looked for a shorted wire or loose connection. Then I changed out the VSS. Changing the VSS seems to have helped, meaning it doesn't quit working as much, but it still does the same thing. Is there anything else that could cause this or am I just missing the short or broken wire? Any ideas????
Jack
Old Feb 18, 2010 | 08:02 PM
MidnitEvil's Avatar
MidnitEvil
Is it just the speedo that quits? Does the odometer go off? What about your headlight?
Old Feb 18, 2010 | 08:03 PM
chuck2000RK's Avatar
chuck2000RK
it is your speedo sensor on the tranny. i had the same issue, replaced the sensor and it went away.
Old Feb 18, 2010 | 08:58 PM
DinoVelvet's Avatar
DinoVelvet
mine does that on occasion.....it will be fine then all of a sudden it drops to zero then all the way over to max speed then back to the correct speed......only occasionally.
Old Feb 18, 2010 | 09:14 PM
jlferguson's Avatar
jlferguson
5th Gear
Yes, it is just my speedo. Lights, tach, everything else continues to work perfectly. I replaced the sensor in the tranny today but that didn't fix it. That is what seemed to make it a little better, but it still does it. And on mine it is not occasionally. I can go 3 miles without it doing this. The worst thing is, as soon as the speedo quits, the speed adjustment on the radio volume quits working and you can't hear the radio.
Old Feb 19, 2010 | 02:52 AM
oct1949's Avatar
oct1949
is it still in warranty? if so take her in...
ChargingRhino
Jun 20, 2014 09:54 AM
thesportyone
Oct 16, 2013 01:33 AM
drs0413
Electrical/Lighting/Alarm
11
May 12, 2012 01:01 PM
fxdx-fly-by
Aug 5, 2011 06:06 PM
Zutroy
May 3, 2007 03:11 PM
