drip,drip,drip.
Old Apr 21, 2010 | 06:46 AM
captain m's Avatar
captain m
Default drip,drip,drip.
I've been trying to stop an oil drip from the primary case on my 07 FXSTC for 2yrs now....I put the case on a trued marble table and it rocks like a chair!!!!!
The gasket surface on the case is concaved and it has "nubs" on the dogs where the screws go....WTF....The gasket is so thin that the nubs were hitting the inner primary case and leaving a gap....I sanded down the nubs and put the case back on with permatex forma gasket and a new HD gasket and the freakin' thing still drips !!!!.......Now....why is it concaved? Why the nubs? and finally where the hell was HD'S quality control ? Any thoughts?
Old Apr 21, 2010 | 06:52 AM
1flhtk4me's Avatar
1flhtk4me
Using a warped cover is not helping anything.
You might be able to sand it flat.Place some double back tape on a flat surface like a surface plate,etc-.then put some sand paper on the tape and sand the cover in a figure 8 motion.
Or replace the cover.
Old Apr 21, 2010 | 06:53 AM
shortride's Avatar
shortride
Sound like you may need a new primary case.
Old Apr 21, 2010 | 07:21 AM
captain m's Avatar
captain m
I think you're right.....time to call the dealer.What a pain in the azz !!
Old Apr 21, 2010 | 07:30 AM
piasspj's Avatar
piasspj
It's probably a bit late now but wasn't the bike under warranty 2yrs ago? You still might try contacting HD.
Old Apr 21, 2010 | 08:06 AM
TheGeek's Avatar
TheGeek
Time for a new cover. I would then check it at the stealer, to make sure it's flat. I had to replace mine (due to someone running into me) when the bike was 5 months old, never had a problem.
Old Apr 21, 2010 | 10:38 AM
captain m's Avatar
captain m
You are right....warranties off...but it was junk to begin with....maybe the dealer will understand this....anyways....here goes.....calling the dealer.
Old Apr 21, 2010 | 02:34 PM
NoBoldRider's Avatar
NoBoldRider
What about the inner primary? Has it been warped by torquing down on the outer to stop the leak?
Old Apr 21, 2010 | 03:23 PM
High Gear's Avatar
High Gear
Did you check the gaps ect with a feeler gauge , just curious how far out.
The sandpaper , carpet tape method should work for you as long as its not to far out,
just take your time with it.
When you get close remove the carpet tape and tape the outer edges of the sandpaper only for a flatter surface yet.( use a finer grit also ).
An hour of your time could save you some serious coin here.
It must have been improperly clamped in the manufacturing process ( when dressing the
mounting surface) or stress in the casting. ( the heat cycling should rule out any residual stress if that was a factor )
I've been there ( toolmaker ).
It wouldn't hurt to check the inner primary with a straight edge also , may be a factor , or could be the culprit.
Old Apr 26, 2010 | 08:22 AM
shortride's Avatar
shortride
It would be interesting to know what cause it.
dproto09
Jan 19, 2017 10:07 AM
magazine
EVO
Aug 16, 2012 10:54 PM
DrWalkinboner
Jun 19, 2011 09:41 PM
hddave2
Jun 28, 2010 02:42 PM
nicksorg
Ironhead
Feb 20, 2007 04:29 PM
