Braking Basics
Old Oct 5, 2006 | 10:45 AM
Dancemax's Avatar
Dancemax
Default Braking Basics
Ok.I know motor cycles 70% front and always use coordinated braking and get in the habit of more front braking and all. Why is it that the regular pedal bikes, you brake rear mostly and hardly use front brakes. Regular bicycles have rear brake on right handle bar. Should i get front brake handle on the right handle bar of my new bicycle to stay in habit for right brake/front and should I also start using more front braking when i ride my bicycle. what is the basic physics of braking in a motor cycle vs bicycle.?
Old Oct 5, 2006 | 10:56 AM
KeithB's Avatar
KeithB
Big Kahuna HDF Member
Default RE: Braking Basics
bicycles don't have aclutch.
Sounds like you understand braking. As you start to get on the front brake weight will transfer forward, allowing you to get on the front brake progressiving harder until you stop. At the same you will be easing off the rear brack.
If you lock up the rear, just leave it locked until you stop. If you lock the front , ease off to unlock it. A locked front brack will take you down.
Old Oct 5, 2006 | 11:05 AM
DMSC's Avatar
DMSC
ORIGINAL: Dancemax
You should use the brakes on a bicycle the same as you do on a motorcycle...by using mostly front brake. Weight transfers to the front tire on a bicycle when stopping the same as on a motorcycle.
ORIGINAL: Dancemax
I know some MTB riders (mostly the downhill crowd) who swap the brakes to "moto" style. I don't see a need for it personlly. I switch back and forth between riding a motorcycle and a bicycle several days a week and have zero problems remembering which one I'm on.
Old Oct 5, 2006 | 11:08 AM
Dancemax's Avatar
Dancemax
quote...... "bicycles don't have aclutch."
Sure, they do. You stop peddling and you have pulled the clutch, lol
Old Oct 5, 2006 | 12:41 PM
Edmo's Avatar
Edmo
On a motorcycle I always start my braking with the front and then lightly add the rear as needed. I tend to use my rear brake more during the last portion of a stop (15 mph and below). Unless you are getting up to big speeds on a pedal bike you are below the speed needed to generate problems. I'm lazy so my pedal bike rarely gets over 20 mph so if I do skid the rear I'm fairly slow. If you are running a pedal bike fast you could have the same problems with skidding that a motorcycle does.
As you apply the front brake, weight shifts forward and increases the amount of down-force on the front tire. This make the front tire "stick" to the road better which allows you to increase the amount of front braking. Assuming you are on dry pavement and have good tires, you will have to grab a huge amount of front brake to make the tire skid. Like it was said above if the front skids, slowly release to get it rolling again and then re-apply.
The rear tire gets "light" as the weight shifts forward during braking. This makes it easier to skid the rear with increased braking. Here is the problem: When the rear tire skids the rear of the bike will try to slide left or right and will tend to get you sideways. If this happens make sure you DON'T release the rear brake until you are stopped. Unlike releasing the front, if you release the rear tire while skidding sideways the bike will violently twitch as the rear tire begins rolling again and the bike attempts to straighten. It can be violent enough to toss you from the bike in a "high-side" ejection.
I hit gravel in a turn and highsided on my Heritage as the rear tire slid through the gravel and then regained traction on the other side. The results of this 45 mph accident were a broken collar bone, 4 broken ribs, a dose of road rash, and a concussion. Lesson learned for me was watch out for gravel and don't brake through it.
Edmo
Old Oct 5, 2006 | 12:54 PM
redscout's Avatar
redscout
I'm surprised no one mentioned that a bicycle will be prone to doing a "stoppie" too.... Not likely you're going to get that 800 lb Harley's rear end in the air, but too hard on the front of a bicycle and over she goes....
I suspect that's why they recommend using the rear brake more....
Old Oct 5, 2006 | 12:55 PM
sleepneagle's Avatar
sleepneagle
If I were you, I'd sell the bike now! it's all ready got you confused.
Old Oct 5, 2006 | 01:02 PM
grumpy irish again's Avatar
grumpy irish again
sorry folks but I don't understand if the rear wheel skids keep on it till stopped
is that what you are saying - Personnelly if my rear starts to skid at all I instantly back off
on it to allow the bike to regain it's normal attitude
otherwise by the time you stop you will be on the ground
one finger on the front brake is all that is needed in most cases and gentle on the rear
also you do have a gear box for slowing I use mine...
[IMG]local://upfiles/5757/DA5652B3FCAF4F04A9EF4F1370203025.jpg[/IMG]
Old Oct 5, 2006 | 02:25 PM
DMSC's Avatar
DMSC
ORIGINAL: redscout
Who's 'they"?
Like I stated in my earlier post...bicycle/motorcycle braking works the same way (use mostly front with some rear brake). Unless you're riding down a steep decent, there isn't much worry about doing an "endo" over the bars. Well, unless you're leaning forward overthe bars while riding.
Old Oct 5, 2006 | 02:29 PM
Motor Squad's Avatar
Motor Squad
ORIGINAL: grumpy irish again
The problem is that if you don't let off the rear brake in that split second before it starts to go to one side or the other you can run into a "high side" situation. The rule of thumb is to stay with it if it locks up and ride it until you stop. In most cases if the back end swings to one side or the other during a rear wheel lock up and the rider lets off the rear brake, the bike will regain traction and try to return to a straight line. When this happens, it can be a violent reaction when the bike returns to the original straight line and can throw the rider off the bike in the opposite direction of the original skid. If you watch sport bike racing, you may see it pretty often when they come into a corner hot and apply lots of rear brake. The bike will swing one way and then swing the other really violently.
Ride Safe.
