Fan kits
Old Jul 17, 2005 | 06:32 AM
1200c's Avatar
1200c
Default Fan kits
Who here has a fan kit like this one?
http://www.harley-davidson.com/gma/g...bmLocale=en_US
Are these worth the money?
Does the fan have enough power to cool your engine properly?
Would an oil cooler work better than a fan kit?
Any problems?
How much does it lower the oil temperature?
Any input would be appreciated.
Old Jul 17, 2005 | 08:44 AM
monkyman's Avatar
monkyman
Default RE: Fan kits
Thats neat, I've never seen anything like that. I'm sure it would help some, but how much??
Also I would like to know how much of a drain it is on the charging system, if it can keep up with the draw at idle.
Old Jul 17, 2005 | 10:56 AM
HDF Tech's Avatar
HDF Tech
Don't have one but I would think it would raise hell with your right leg because of the heat it blows off the motor, seems like a decent idea in theory but it would give the battery on these bikes a workout at idle, you'd be running pretty much off the battery at idle , then at speeds the alternator would take over again , but the fan is not needed then. Couple the fan with the lighting on the bike and I would think that would be excessive draw at idle. JMHO
As far as your other question on the oil cooler, look at it this way. With the oil cooler, you would go into a stop and go situation with cooler oil so it would take longer to heat that up also.
Old Jul 17, 2005 | 01:30 PM
pilot1996's Avatar
pilot1996
To echo what TCSTD said...I just did the oil cooler thing on my ride. While it doesn't "cool" at idle, it does allow the bike to run cooler when not at idle, and the bike is cooler when you get to the stop light. This is what determined it for me...
Mac
Old Jul 17, 2005 | 03:25 PM
1200c's Avatar
1200c
I wouldn't go by your right leg it would go by your left leg. You would take off the horseshoe horn cover and horn and mount the fan kit in that location. Relocating the horn. I've never had a problem with my leg hitting the horn, so I don't think that's much of a concern. The engine is hot already. It can't blow off anymore heat then is in the engine.
That's one of the concerns.
The other concern is does it really work. Will it lower oil temper by 20+ degrees like they claim? Is the fan powerful enough to draw away that much heat from the engine?
It seems like a good idea. An oil cooler doesn't work well when you're idling. If this fan would work during idle, then that would be a solution. Without having to have an oil cooler than might lower your oil pressure.
I would love to hear with someone that has experience with this device.
Old Jul 17, 2005 | 04:08 PM
HDF Tech's Avatar
HDF Tech
Yes I understand the fan goes by your left leg but which way does it blow? out the right or "suck" to the left??
pilot1996's Avatar
pilot1996
Wire it through the brake light...if you start having excessive drain, you take your foot or hand off the brake. Only time you want it to run is when you are idling anyway...right? Wouldn't help for 5 mph traffic though...
Mac
Old Jul 17, 2005 | 07:30 PM
HDF Tech's Avatar
HDF Tech
OH Boy, somebodies got their thinking cap on, great idea, all you need is a relay like the starter relay, and we all know where there is a wiring plan for that....right?
Old Jul 17, 2005 | 11:58 PM
1200c's Avatar
1200c
Great idea mac. Now the only question in my mind is whether it will have enough power to pull enough heat away from the engine. The buells use dual fans and an oil cooler to cool the engine.
Nickd2689
May 23, 2019 11:05 AM
No H2O
General Topics/Tech Tips
30
Aug 25, 2018 11:00 AM
FotoDeville
Jan 16, 2011 07:23 PM
990rtracer
Jul 12, 2010 08:36 AM
spiritwarrior
Apr 15, 2008 07:13 PM
