Softail starting question
Old Mar 1, 2012 | 11:24 PM
dickey's Avatar
dickey
Sorry, but I think that's a load of crappadoola. I have never EVER used the handlebar switch on any of my Harleys & never had a problem. Carbed, EFI,Evo, doesn't matter. Reason I don't use the switch is 'cause it's too easy to hit the starter button by mistake while the engine is running. Seen my friend & my GF do it after I warned 'em to forget that switch even exists;doesn't make a pretty sound! For all I know the handlebar switches on my bikes could be rusted in the "on" position;wouldn't make a bit of difference. Tank switch is the only one I use.
Old Mar 2, 2012 | 01:03 AM
PigInaBlanket's Avatar
PigInaBlanket
I agree with dick. That shouldn't make any difference. I do however always use the kill switch on my bike since the key is in the neck and harder to reach to shut off the bike.
The little myth that I hear a lot about that you should wait till the diagnostic light goes out to start your bike is a load of bull too.
Sometimes in the summer after riding then shutting off the bike for a short time, mine is a little hesitant to start right away too. Doesn't do it often but it has happened. I attribute it to vapor lock.
Old Mar 2, 2012 | 09:14 AM
bikefxds's Avatar
bikefxds
Thanks dickey and PigInaBlanket for your input. My wife's and my 2010 Deluxes are identical. Same mileage, same serivice intervals, same riding style to the tee. We had '09 baggers that we started and stopped by the book. The Deluxes had about 5K on them when I deviated and started not using the handlebar switch. That's when the starting glitch happened. For the past two days I've changed nothing in terms of riding style, destinations, coffee stops, etc...the only thing I changed is I went back to the book procedure and it cleared the problem up. I ain't sayin' that the vapor lock or dirty fuel filter things don't exist...of course they do. I'm also not implying that an inadamite object like a motorcycle has a "heart" or "feelings", but I'm a firm believer in when you deviate from a procedure that you've used since break in, it could cause some glitch somewhere. I have never accidentally hit the start button as Dickey's friend did. I've seen it done, but my wife and I are so "brainwashed" in how our thumbs act at the throttle and handlebar switch, it has never been an issue. Anyway bro's, thanks again for the input. I'm gonna use the switch.
Old Mar 2, 2012 | 09:28 AM
Very High Plain Drifter's Avatar
I agree. The sequence I use is: Tank Ignition switch (wait for security light to go out) -- Handlebar switch (wait for engine management light to go out) -- Press Start -- giggle hysterically at the sound.
I know you don't have to wait for the lights to extinguish, but why confuse the poor thing?
Every vehicle I've ever had, from the the '66 Land Rover I had to my '11 Road King, has a sequence that worked first time, every time. Not that the vehicle won't start any other way. But there was a way it liked to be done.
Old Mar 2, 2012 | 07:58 PM
PigInaBlanket
Hey, if it works for you then keep on doing it.
Old Mar 3, 2012 | 08:50 AM
bikefxds's Avatar
bikefxds
I am a believer in not giving these newer motorcycles any excuse to leave me sitting at a stop while everyone else is moving out! No matter if it's the book sequence or a word of mouth type thing, if the bike gets used to one method I believe it should not be deviated from. I had a 1990 FLHS that got used to turning the ignition switch on, two blips of the throttle then holding the throttle open just a hair and it would fire every time. If I did the first two but forgot to hold the throttle open, the thing would just not fire. I'm stickin' to the book method on this one 'cause that's what's worked until I deviated from the norm.
carburetorjones
Aug 24, 2019 01:47 PM
Mchad
Aug 7, 2018 09:52 PM
chaz mcnasty
Jun 11, 2013 09:01 AM
ironsheik
May 14, 2011 02:37 PM
Sftail291
"The Florida Crew"
Dec 31, 2009 03:42 PM
