noticed some rust
Old Jul 19, 2012 | 01:11 PM
rufasim's Avatar
rufasim
Default noticed some rust
Took the bike this am to work. As I was pulling it out I noticed some rust on the passendr peg mount. It was inside the bolt holes that are not used. I swore there was paint in there. Should this be a concern. 2012 sg. Going in for 5k next weekend
Old Jul 19, 2012 | 01:14 PM
purpledeuce's Avatar
purpledeuce
Nope, mine are the same and every other one I've ever seen is also the same
Old Jul 19, 2012 | 01:16 PM
NoRegerts's Avatar
NoRegerts
A little CLR on a cotton swap, then come clear nail polish if you want. Run a bolt through first then CLR to clean it well.
That's if it bothers you. I have some bolts that wanted to rust on the inside. I did that.
Old Jul 19, 2012 | 01:17 PM
Scaredofrain's Avatar
Scaredofrain
Mine are too. I sprayed the inside of the holes on mine using one of these "staw" thingies of the clear body undercoat can.
Old Jul 19, 2012 | 01:18 PM
Sweetbaboo's Avatar
Sweetbaboo
Well, time to trade.
Old Jul 19, 2012 | 08:10 PM
Hogwallop's Avatar
Hogwallop
You need to go beyond the obvious to find rust. I had the same thing, but what got my attention was the thick rust on the inside of the air breather cover along with the rust on the underside of the floorboards, the battery box and under most of the chrome parts. I used a spray on rust converter along with spray on rubber coating on all the rust damaged areas to prevent any further rust development. Catch it early to prevent any rust blow through.
Old Jul 19, 2012 | 08:54 PM
oldairboater's Avatar
oldairboater
Treat all rust. I can't let it go.
Old Jul 19, 2012 | 10:46 PM
dickey's Avatar
dickey
Your bike is ruined beyond repair. I'll give you $1000 for it, sight unseen.
Old Jul 19, 2012 | 11:09 PM
BassCatcher's Avatar
BassCatcher
Clean it up. It makes no sense to leave rust anywhere on your bike.
Old Jul 20, 2012 | 05:41 AM
Harley Tim's Avatar
Harley Tim
See my Avitar....
Best wishes....Tim(HT)
