Copd
really small budget: pipes+ac+xieds
medium budget: pipes+ac+tuner+dyno. But really at this point since you are forking out for the tuner+dyno, you may as well do the cams and dyno all together, therefore : pipes+ac+cams+tuner+dyno.
With pipes+ac+cams+tuner+dyno your 96" will be already a different beast and it will pull very very strong.
103 kit = money
Head/valve work = money
Cams = money
Do all of the above, including the pipes and air cleaner may run you $6k+. Maybe $4k if you do all the work yourself.
You should be able to do the pipes, air cleaner and tune for under $1,500.
Man, I almost couldn't believe it-this new HD motor looks like a home run.
10.5 CR out of the box for pump gas, top of the line parts with a strong bottom end, almost pro level heads, 135 HP (and more with the optional 12-1 pistons), and a price point that is just incredible. Available as a complete crate motor from certain dealers for under 5k with discounts plus requires separate purchase of appropriate Screamin E agle
throttle body, high-flow injectors and a high-performance
clutch upgrade. Just add your choice of race exhaust, highflow
air cleaner, and tuning. ...then smoke all your friends...
I have been an S&S guy for years, but geez, this thing just rocks...
Screamin EagleŽ pro SE 20R High-
Performance Crate Motor
This track-ready 120 cubic inch Screamin E agleŽ Crate Motor
is waiting to provide a racing enthusiast the opportunity to
go racing at an affordable price. This engine is designed for
bolt-in installation in the Original Equipment-style chassis
of your track bike. No special fabrication or engine-mount
relocation is required. The crankcase, cylinders and heads
are painted black, and feature machined aluminum highlights
and chrome covers for a stunning show-and-go look.
When equipped with appropriate high-flow throttle body
and injectors, an open air induction, and tuned exhaust, this
engine is capable of producing a reliable 135+ horsepower
at the rear wheel.
Hand assembled alongside Harley-Davidsons production
Twin Cam engines at the Pilgrim Road Engine Plant in
Milwaukee, these race-use engines feature only the finest
Screamin Eagle components:
4.060" big-bore cylinders.
4-5/8" stroke premium forged flywheels.
10.5:1 high-compression nickel-plated forged pistons with
T eflon coated skirts.
Titanium SST piston rings.
SE-266E high-lift cams.
Perfect Fit push rods +.030.
SE high-performance lifters.
CNC-ported MVA heads with automatic
compression release.
Machined lower rocker boxes for valve
spring collar clearance.
Factory-machined engine cases.
Unique piston oilers for stroker clearances.
Screamin Eagle inner crankcase cam needle bearings.
Lefty high-performance crankcase output bearing.
High-performance torque response engine compensator.
SE Performance Spark Plugs.
For race application only.
19220-11 Black & Chrome. $5,495.95
Fits 06-later DynaŽ and 07-later T ouring models.
19206-11 Black & Chrome. $5,795.95
Fits 07-later SoftailŽ models.
