Please help...
Old Feb 12, 2007 | 05:15 PM
anubisss's Avatar
anubisss
Default Please help...
Evertime I turn it on, the key stays on for a second with the FI engine light before i start it. Someone said I had to ahve the stealer reporgram the bike since I added the smart siren II. Where can I find out how to do this myself? I have the manual, but didn't see anything about this in there. Please help...Thanks.
Old Feb 12, 2007 | 05:27 PM
SteelCityScooter's Avatar
SteelCityScooter
Default RE: Please help...
Well,
Your post tells me you are shuting down your bike with the ignition and not the kill switch.
Just went out and tried mine,(06 Ultra) and with the kill switch in the OFF position, the little key light comes on with the ignition switch and shuts down after the computer cycles through. Then the FI engine light will come on and cycle through with the kill switch being cycled to ON.
BUT......
With th kill switch in the ON postion when turning on the ignition, BOTH lights will cycle through at the same time. (the FI telling you it has primed and pressureized the system, and the key with the self diagnistic check)
Old Feb 12, 2007 | 05:33 PM
anubisss's Avatar
anubisss
Thanks for that info. Sometimes I use the kill switch and sometimes the ignition. I'll try kill switch only from now on...
Old Feb 12, 2007 | 05:36 PM
IAMSWUTIAMS's Avatar
IAMSWUTIAMS
That's a good boy
Old Feb 12, 2007 | 05:43 PM
Panhead_1_9_4_8's Avatar
Panhead_1_9_4_8
ORIGINAL: anubisss
In your previous post ... you said you added an alarm module ... not a siren. Alarm modules have to be programmed to your bike at the dealer.
Old Feb 12, 2007 | 05:45 PM
anubisss's Avatar
anubisss
I meant siren. Sorry panhead1948, gotta reread these posts before hitting ok...
Old Feb 12, 2007 | 05:57 PM
glebo's Avatar
glebo
ORIGINAL: anubisss
whats wrong with using the key to turn off your bike?? I do it all the time, I dont think I have ever used the kill switch, on purpose that is. (I have no alarm or siren, does that make a difference?)
Old Feb 12, 2007 | 06:10 PM
SteelCityScooter
When using the key to sut down, you are shutting down the entire eleltrical system at once with the motor. (Motor, lights, radio,accessories,etc)
Killing the motor with the kill switch, trains you to its postion, and also is just a bit easier on the electrical system of the bike.
Old Feb 12, 2007 | 06:14 PM
anubisss's Avatar
anubisss
I see. Thanks for the info.
hotrod1340
Electrical/Lighting/Alarm
Nov 11, 2016 07:42 PM
hpotter
Oct 31, 2014 05:24 PM
RK2010
May 1, 2011 07:56 PM
masterblaster
Dec 11, 2010 08:12 AM
klagair
Apr 9, 2006 07:01 AM
