broken primary chain.
Old Sep 28, 2014 | 05:32 AM
AnaChris's Avatar
AnaChris
Default broken primary chain.
I have a 2003 flhrci with a broken primary chain. the inner is broken under clutch basket. Looks like all else is okay. found an inner for 50 bones but still have 2 questions.
#1 best chain?
#2 best way to break the comensator nut with no chain....well i have it.
thanks in advance
Chris
Old Sep 28, 2014 | 05:55 AM
Stiggy's Avatar
Stiggy
Curious as to what broke the chain in the first place? Only way to break the comp nut loose is with an impact gun IMO. (Your crank is still forged (tho' your motor doesn't have the dual Timken lefty bearing,) and the impact gun should still be just fine.)
I don't think anyone makes a bad primary chain, but if I was buying I'd get one made by Diamond.
Old Sep 28, 2014 | 06:17 AM
AnaChris's Avatar
AnaChris
The crank is a new S&S (stock build nothing special). I agree that an impact is going to work it offf but how to hold the damn thing. why did it break? dunno.
thanks I am seeing lots of info on the diamond chains. think Ill attatch the broken chain to the broken chain case. can't do any more damage right? and pull against it.
Old Sep 28, 2014 | 06:39 AM
hvacgaspiping's Avatar
hvacgaspiping
In your situation the impact gun is the best way to go. You don`t need any back up when you use the impact gun, either. Just make sure the impact gun is turning in the correct direction.
Old Sep 28, 2014 | 06:40 AM
AnaChris's Avatar
AnaChris
got to workin' it and found the locking tool will ride up against the case with one end of the chain in the sprocket. thanks.
Old Sep 28, 2014 | 06:49 AM
AnaChris's Avatar
AnaChris
I did hit it with the impact locked against the case. easy peezy....
Old Sep 28, 2014 | 09:24 AM
JustDave13's Avatar
JustDave13
An impact gun concentrates all the turning force on to the nut or bolt you're trying to remove.
One quick little zap with the gun and the bolt will come loose without the surrounding components turning, this is one of the cool features of using an impact.
Wisenheimer16
2014-2024 Touring Models
21
Jul 4, 2017 05:34 PM
Rickity
May 2, 2017 08:06 PM
texashillcountry
EVO
Oct 24, 2012 10:21 PM
azharleyrider86401
Apr 8, 2011 05:43 PM
jadev
Sep 27, 2010 02:28 PM
