Blinker problem, 99 WG
Old Apr 10, 2016 | 06:43 PM
LDB187's Avatar
LDB187
Default Blinker problem, 99 WG
Changed the bulbs but still not blinking. Lights just stay on solid, no blinking. Whats the fix? TIA
Old Apr 11, 2016 | 10:41 AM
grbrown's Avatar
grbrown
Your bike has a flasher unit which may have packed up, however check the wiring to make sure there are no broken wires, or dirty/rusty ground connections, as those sorts of things can interfere with proper functioning.
Old Apr 11, 2016 | 12:48 PM
LDB187's Avatar
LDB187
I guess I should have said that it is the left blinker only. Right blinker works just fine. Are there two seperate units? Thanks
Old Apr 11, 2016 | 02:01 PM
grbrown's Avatar
grbrown
Wink
No, only one. Move on to:
Originally Posted by grbrown
.....however check the wiring to make sure there are no broken wires, or dirty/rusty ground connections, as those sorts of things can interfere with proper functioning.
Swap your bulbs from right side to left side, to see if the problem goes with them. If it does your bulbs are defective.
Old Apr 11, 2016 | 04:56 PM
LDB187's Avatar
LDB187
yup, we already tried that also. when we turn the left blinker on both front and rear just stay on. it started with the front (after market) blinker bulb being out. figured the bulb change would have cured the problem but now both front and rear stay on. there was some corrison on the front connections but we cleaned it off pretty good.
Old Apr 11, 2016 | 05:39 PM
14GuineaPig's Avatar
14GuineaPig
And when you tried swapping bulbs it was right front to left front and right rear to left rear. In many cases the front and rear blubs are different and not interchangeable. Most fronts are 2 elements while the rear is usually a single element.
TPost
Electrical/Lighting/Alarm
Nov 28, 2016 02:43 PM
patcham48
EVO
Feb 26, 2013 01:50 PM
theyammieguy
May 2, 2011 07:41 PM
ssls6
EVO
Feb 27, 2008 08:45 PM
FLSTSI
May 26, 2005 05:33 PM
