General Topics/Tech TipsDiscussion on break in periods, rider comfort, seats and pad suggestions. Tech tips as they become available will be posted here.
Put gas in the bike last night, rode about a mile home, everything fine. Going to work this morning, it starts up as it always does, but sputters and bogs down as I get on the street trying to accelerate and go through the gears. Had to limp home and get the other bike.
Thinking it could be a clogged fuel filter or something in the line? I did have to put the bike on reserve on my way home last night. Can't see that as being the problem.
Guess it's as good a time as any to put the cams in the bike.
Sure would like to know why it's doing this though. Have to check into it tonight after work.
Any suggestions?
You just might have hit it when you adjusted the Idle and everything was fine --- I'm not familiar with your carb but the carbs that I am even some Jap bikes have a O-ring and a washer under the Idle screw , Remove your Idle screw unravel a paper clip bend a end to 90 degrees cut off to 1/16 inch and reach down in the screw hole tho hopefully find a washer and O-ring it might a couple of try's . Auto's do not have this only motorcycles, atv, ect -- you might also try to find a parts brake down , If the o-ring is there you will only find it in a over haul kit --- I hope that's it -- a easy fix , many people replace the whole carb because of this 10 cent O-ring
