Brake Fluid Replacement
Old Mar 14, 2019 | 05:25 AM
e6fmf's Avatar
e6fmf
Default Brake Fluid Replacement
DO NOT IGNORE. 2016 Roadglide CVO with ABS. My situation.
About 20K miles. Started with warped left rotor, replaced both. 40K miles front end shaking violently. Left rotor burned, left caliper locked up causing wheel bearings on right front to disintegrate. Replaced both front rotors and pads and new bearings, including ABS wheel bearing. New fluid. I allowed fluid to get too low. Trip to dealer for recalibration. VERY EXPENSIVE LESSON.
Old Mar 14, 2019 | 07:48 AM
CoolBreeze3646's Avatar
CoolBreeze3646
I would think if the proper Service intervals were followed and performed at the dealer or other responsible party, the problem would have not presented itself.
Just wondering about the title of your post and what brake fluid levels have to do with warped rotors and wheel bearings going bad. Seems like a maintenance problem to me.
Good luck.
Old Mar 14, 2019 | 08:11 AM
bustert's Avatar
bustert
sometimes, doodooo just happens. best to get into a pre-ride inspection habit. drove 18 wheeler off/on for 2 yrs. it was a must, mainly for safety, besides required by dot and any vehicle violations are against the driver.
Old Mar 15, 2019 | 09:28 PM
Ed Ramberger's Avatar
Ed Ramberger
Please explain how the dealer claims low brake fluid did this. I don't see it. Sounds like you had a bad left caliper or hose to caliper collapsed internally. Also don't get the left caliper causing the right bearings to fail.
mcgee10
Jul 8, 2019 07:18 PM
donnie1
May 26, 2018 08:51 PM
RGC WILLIE
Nov 7, 2015 09:17 AM
billbuzz
Mar 19, 2014 12:23 PM
anubisss
Oct 3, 2007 04:10 PM
