Installing parts question?
Old Mar 24, 2005 | 10:39 PM
Bad Guy's Avatar
Bad Guy
6th Gear
Default Installing parts question?
Just purchased the chrome switch housings and chrome master cylinder/ brake bracket for my new fatboy. I have two questions: is it best to have the service manual before tackeling this project and are there any problems I should anticipate with this installation. Any help/suggestions would be greatly appreciated.
Old Mar 24, 2005 | 11:05 PM
Lovetoride's Avatar
Lovetoride
Default RE: Installing parts question?
I don't think that's a big job. The only thing you might not have is a pair of split ring pliars...
Ryan
Old Mar 25, 2005 | 12:38 AM
pilot1996's Avatar
pilot1996
Definitely get the service manual. It's well written and easy to follow. You can read what you're getting into, look at the pics and then decide what you want to do.
Mac
Old Mar 25, 2005 | 01:02 AM
stangnut's Avatar
stangnut
I try to avoid sounding like a broken record, but they're right... You'll never go wrong if you buy the manual... I read mine cover to cover before I changed the oil...
rich
Old Mar 25, 2005 | 03:57 AM
hawk's Avatar
hawk
You can't go wrong by buying and using the service manual
Old Mar 25, 2005 | 04:16 AM
investorsc's Avatar
investorsc
Read the top of the master cylinder closely before you add any brake fluid. My new ULTRA is DOT 4, not 3 or 5. The dealership was quick to point that out, because many people and shops use what "their used to"....The manual is a requirement and a worthy investment for any bike and an owner who wants to turn a wrench or screwdriver on the bike. Hey- what is your time worth... A screw up will cost you lost of time (Wouldn't you rather be ridin'?), not to mention a possible messed up part expense!
BRUCE
Old Mar 25, 2005 | 07:12 AM
00hawg's Avatar
00hawg
The Service manual is always nice to read through before tackling any job, minor or major. Installing chrome controls is relatively easy. A little more time consuming if you have to add on to your wires if you install taller handle bars. You will want to make sure you use the correct brake fluid as investorsc stated, when you fill the master cylinder. Bleeding the brakes is pretty simple, just as you would on a car. You can do it. Take your time and you'll be back on the road with some new bling in no time.
Old Mar 25, 2005 | 11:03 AM
John TN's Avatar
John TN
What they said
Old Mar 25, 2005 | 03:11 PM
igniter's Avatar
igniter
The very first thing I do is purchase the shop, parts, and wiring manuals. I do this for my trucks, cars,m and bikes. It helps when working on them. The parts helps to figure out how things go together, etc. And the wiring is something you can't do without if you have any elec. problem. Just a thought.
Old Mar 25, 2005 | 07:35 PM
Bad Guy's Avatar
Bad Guy
6th Gear
Thanks all for the feedback. I am off to get the manual.
