Handlebar grips
Old Jun 22, 2006 | 07:27 AM
Delrob's Avatar
Delrob
Default Handlebar grips
Hey guys was just wondering if any of you folks have changed your grips? I got myself a new pair of the "flame" chrome ones and was wondering if you guys used glue or any other tips on fitting or changing them.
Thanks in advance
Delrob
Old Jun 22, 2006 | 09:29 AM
Woodyheritage's Avatar
Woodyheritage
Default RE: Handlebar grips
Personally I don't care about the grips coming off, if I need to cut them I will. As far as going on, make sure the area is clean and dry and then I spray some hair spray into the nedd grip and pop it on. Make sure you have it in the right direction(design wise-skulls would be up and down at rest) wait about half an hour or so, works best if you can give it overnight to coagulate inside the grip.
Good luck
Woody
Old Jun 22, 2006 | 11:03 AM
fxstcguy98's Avatar
fxstcguy98
My grips were HD and they have a flange on them that holds them in the switch housings. So, no glue needed for those. If they don't have that, then use the hairspray or rubber cement or epoxy if you really want them to stay.
Old Jun 22, 2006 | 11:27 AM
jt1965's Avatar
jt1965
I also did not use glue.
I mean you only glue the left one on and they both have flanges to hold them there.
Get some extra brass ferrules just in case.
Old Jun 25, 2006 | 11:28 AM
Delrob's Avatar
Delrob
Managed to get the left grip fitted ok and like you said it has the flanges as they are the HD flame ones, thing is it says check service manual regarding throttle etc, and i dont have one. Is it easy eneough to change the right grip or should i take it to someone that knows?
Delrob
Old Jun 25, 2006 | 12:29 PM
Alien Spyder's Avatar
Alien Spyder
Very easy to do the right grip. Do you have a service manual for your bike?
No matter what job I'm doing, I like to read the manual and check with forum members about possible problems I could run into.
I recently put some Iso Grips on my Train and it was a breeze! You should at least read over the paper work that came with the grips. That should be sufficient.
Good luck. Let us know how ya make out!
Old Jun 25, 2006 | 12:35 PM
Delrob's Avatar
Delrob
I got an owners manual but no servce manual, was just wondering about the way to do it, loosen clamp first i take it, was wondering regarding the sleeve and the cables
Old Jun 25, 2006 | 12:38 PM
Alien Spyder
Let me check my memory banks here.................
Lets see, I remember pulling bach the sleeve and measuring or marking where the lock nut is so that when I'm done I can tighten the cable back to it's original position.
I'm still thinkin about the job I did on my bike................Hmmm!
Old Jun 26, 2006 | 06:10 AM
Delrob's Avatar
Delrob
THanks for the help spyder, job complete. Trickier than expected as the return throttle cable came loose from the assembly between the V's of the engine and had to take out air filter and carb to get it back in. Ok now though and the flame grips look great
Old Jun 26, 2006 | 11:31 PM
Alien Spyder
Cool man! Glad it worked out. Do your self a favor though and invest in a manual. It's worth the $50 bucks!
Machine213
Jul 16, 2018 04:51 PM
randy98ss
Jul 28, 2015 10:48 PM
parts eeter
Oct 14, 2010 06:49 PM
LoRyder
May 24, 2007 06:16 PM
jbhawley
Apr 26, 2007 09:30 AM
